Omega De Ville (Classic) Dress Watch Battery Replacement
Jiggz
Hello all,
With my success (through this forum's help)  on my classic Rado, I've decided to try another battery replacement on what I believe is a more complicated watch. I've not worn this watch for decades due to outrageous price for battery replacement. However, with this forum I hope I can get some help on how to do this properly. There are four screws on each corner of the backing. I believe the screws are holding the top case with the glass or crystal thus access is through the crystal. However, if this is the case how do you remove the winder's crown to access the back of the movement? I do not believe the four screws are holding the stainless steel backing for the stainless steel backing also holds the wrist band unit. Any help is greatly appreciated. Here's a couple of pics.
Where these small screws are used to hold the caseback in, I have found that they sometimes give a lot of problems as they tend to get stuck.
It is very important to realise this from the start. Clean all the crap around the screw. Use a good quality screwdriver and makes sure that it is the correct size. If it seems tight, stop and consider using oil/heat. Do not use more force as you will end up messing the screw head and having to drill out the screw.
Anil
Anil,
Thanks for the response. So if I unscrew the 4 screws, am I correct in assuming the access will be at the crystal or will it still be at the backing? And if access is at the back does that means the wrist band goes out with it? On a safety note, where can I get replacement screws just in case the existing one are stripped? Thanks again.
Anil,
I tried and was able to unscrew all four screws with very little fuzz. One screw was a little tight but after soaking it with a bit drop of oil, it finally unscrewed. So now I've got the crystal/bezel off but still unable to access the battery. I guess I have to remove the winders' crown to fully dismount the internal and get access to the battery. How do I go by doing this? Do I need a special tool to do this? Thanks again. Here's a pic with the crystal/bezel off the watch.
Edited by Jiggz
ok we've established that it comes out the front.
Option 1
Look at the gap between dial and case near the stem ... pull the crown in and out... do you see anything moving in the gap? some watches have the stem release visible in the gap. You will need to use a small needle to press on it and pull the stem out if so.
option 2
1. pull the crown out to the time setting position.
2. flip the watch over, the side away from the crown will fall out a bit. Jiggle it about while turning the crown and lightly pulling on it.
Some two piece stems can be released this way but you seldom see two piece stems on quartz watches.
Option 3
If this fails to do the trick, the next thing I would do is pull the hands and see if the dial lifts off. The dials looks to be held securely by the bezel so it could be a friction fit into the movement. This is a bit involved and if you're not careful you may end up destroying the watch.
hope this helps.
Anil
Wow!, Option 2 did it. Thank you very much for all the help. I would have not in my wildest imagination figured it out how to access the battery on this watch.  Now I fully understand why watch repair people are charging such outrageous price to replace the battery. Thanks again.
Glad I was able to help!
would it be too much trouble to get a few pictures of the stem components? Most of the ones I've seen are for mechanical watches, quartz stems are usually thinner so it would be nice to see how Omega did it.
Anil
Here are pics of the empty case with the winder stem and crown still in place and also removed. I can actually remove the winder unit and re-insert it. The stem has some kind of flat o-ring to keep moisture and dirt out. The stem connection to the movement looks like an "open clevis". I wonder if reinstalling is just a matter of pushing in the stem into the movement. Or do I have to align the clevis with the stem?
Great pictures for future reference Jiggz, and a big thanks to Anil for excellent guidance.
I'm sure that once you reassemble the watch, you will only have to align the watch stem with the slot and push it back into place. Hopefully Anil will confirm this.
Thanks Geo. With forums like this, I've learned through times that the old saying, "A picture paints a thousand words" is actually the other way around, i.e. "A word paints a thousand pictures while a picture paints only a word" In short, with pics you actually say what you mean and mean what you say. Great forum.
yeah.. you'd need to get the angle right. But in this case its much simpler as you can play with the move and crown/stem wthout the case to see which is the best angle.
Main thing is not to use too much force..I would think sourcing the stem components would be a challenge.
Oh and lube the screw threads when you close it up..
Anil
Great info for an unusual watch and movement casing. One more for the knowledge bank!
Regards greasing the case screws, I would use anti-seize paste or silicone grease.
Most normal greases have a fair amount of water content through the manufacturing process and once the corrosion inhibitors have been used up over time, will allow the steel to corrode, especially in the more exposed parts outside the case.
Some of us will remember the exposed brake cables on old cars which rusted underneath the grease!!!
  • Similar Content
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
