PeterS
Second light - shadows problem
I struggle with lighting. I have a good 21 Watt, 6500 K led desk lamp but I need something additional due to shadows. Oiling jewels is difficult, slots in screw heads can be difficult to see…
I do have a little led lamp (in the picture) but that’s too high and doesn’t help at all.
I could get an adjustable floor lamp and put a good bulb in it but it’s not very practical, I’d have to keep moving it out of the way all the time.
I’m thinking of a ‘goose neck’ led lamp:
https://durston.com/product/durston-led-goose-neck-lamp-dim-cct-white-eu-plug/
Is there something good around 15W I could get?
Share this post
Link to post
How about making the room lighter. Better main lighting. If you have a window in the room, how about moving you bench around to benefit from that. The table top could be a lighter colour.
Share this post
Link to post
I usually get to tinker with it later on when it’s dark. I just bought two 15W cool light - light bulbs for the room, it helps a little but it’s not great, it’s too high in the ceiling. Ideally I could do with something behind me (from the side) and fairly close to cancel the shadows but having a floor lamp would be very awkward. Ideally I’d like something I could put on the desk, sort of a spot light that’s powerful and I could move about and direct the light where I need it.
Share this post
Link to post
Hi  Whats the possibility of building a frame fitted to the desk  with an overhead flourescent tube or double tube assembly over the work area, Inconjunction with the desk lamp it should minimise the shadows.  If the height is made adjustable up/down it would be even better.
Share this post
Link to post
I use this LED light. It’s small, standing eleven and a half inches tall. The top of the light flexes so you can move it into different positions. Sometimes it’s too bright so I tape a piece of watchmakers paper to the light to diffuse it a bit. Costs $29.00. I ordered it online from Office Depot.
Picture is has the light on my workbench.
Share this post
Link to post
I’d love that but I don’t have a dedicated desk, it will have to be an additional light that’s easy to put away and ideally not too big.
Share this post
Link to post
Picture is has the light on my workbench. imageproxy.php?img=&key=77f0dcc5ac0f9d5b
Yes, something like that might do the job. In many ways similar to the goose neck lamp I’m looking at.
If only I knew what I need. The light in the picture I posted is very good (not the small one), it’s the fact that it is slightly in front of me hence the shadows. I can move it right above what I’m working on, but again, there will be shadows elsewhere because my hand and head will get in the way.
I’m starting to think that a floor lamp next or close to me will be the best solution, casting the light from opposite direction. A head torch would be perfect but I don’t want to sit there with it on for hours.
When I look at Mark’s oiling videos (jewels) it’s so clear, yes it’s a lot more magnified than my 12x loupe but there are no dark areas.
Share this post
Link to post
Thats  a poser,  what I had fitted to the bench at on time was a four in line which used halogen bulbs the same thing uses LEDs now and fitting that up with some 2by1 and made colapsible so that it folds up. the multiple light array should go some way to removing the shadows as the lights strike at different angles,  if it has a decent base a G clamp will fix it to the table/bench, food for  thought.
Share this post
Link to post
I don't know if you need diffused or spot light but the latest LED tubes of natural light are amazing. 7 - 8 euro gets you 1.50m at 18W, just use two holders at the end, you can set it on a wood board or what you like.
Share this post
Link to post
Hi Peter     Been racking the brain cells, Was thinking on the lines of making your own anglepoise type lamp to your own spec using the 2x1 hinged  and clamped to the bench, as jdm says you can get some LED lights with good light out put and they run cool, better than halogen. Istead of the standard lamp head use a timber rail and mount the lamps on that. parts required are some M6 bolts with wing nuts and some wood. the bolts and wing nuts form the hinge in the wood with a washer each side to tighten the angle when in the required position. If you want a rough drawing message me.
Share this post
Link to post
18W sounds great, can you post a link so I know what I’m looking for? I'm sure I would find something similar in the UK.
Share this post
Link to post
Yes please, a rough drawing would be fantastic. Thank you.
Share this post
Link to post
12 hours ago, ro63rto said:
These come up every few months in Lidl. I got mine for £12.99
Multiple Kelvin settings to suit and plenty bright enough.
That looks far better than the one I have. I don’t think mine goes up to 6500K. Mine makes no difference at all when I have the bench lamp on, not even worth switching on. It’s few years old now and the bench light is fairly new.
Share this post
Link to post
That is the light temperature not the intensity. 6500 is ice cold, I suggest you try 4000 natural white, it's a matter of preference after all.
In the electric shop ask for a LED tube of the length you want, and the two bare holders, you will need to wire one only. These items are so cheap is not worth to buy online.
Share this post
Link to post
Hi Peter  can you PM me your address I have roughed out the idea and will send it to you as soon as. The design is simple based on the anglepiose but made from wood relying on friction joints with no springs so can fixed to suit.      Cheers
Share this post
Link to post
Loading...
    • Welcome to the forum
    • I cleaned the hole thing, and oiled it using 9010 and hp1300. On the exit stone of the first pallet I put a drop of 9010, I've seen others using it although I now it's not the best there. I didn't oiled the second pallet. I have no photos of the timegrapher screen, and as I do not have a permanent desk I have uninstaled it. I'll take some photos next time I check the watch. But the data I gave is about what you can see there, the lines are very clean and nice in all positions except crown down, where they are quite messy. Lift angle was established at 53.0. I do not think there is any other relevant information you can see on the screen, is there?
    • Does your timing machine show a graphical display you can show us? Besides swapping escapement components what other servicing have you done to this watch? Plus what sort of lubrication are you using especially on the escapement components.
    • BLEURGH! Don't know how that ever became a "delicacy" in the Philippines!
    • We need a clear picture looking in sideways at the hairspring and balance wheel in the watch. Then yes technically her out a center but it's minimal it shouldn't be the cause of amplitude problems. They hairspring not flat would be a cause of problems especially when it's touching something. Can we get timing machine results? And that includes the graphical display with the numbers.
