anybody know where i can obtain blue or black hands for a waltham pocket watch 1.90 x 1.18 at a reasonable price.tried Cousins but they dont seem to have this size and although there seems to be plenty on E-bay they are mostly from the USA with ridiculous postage charges.thanks B.
sorry to tell you but you cant buy these hands from suppliers. Ebay is the way to go but try searching based on movement size instead of hole size you will get more results. plus shipping should not be too much since most sellers participate in the global shipping program which allows you to ship an item to any country outside the US for the same cost as within. The items gets shipped to an exchange center in Kentucky where they ship the item to the destination country, its great because the exchange gives you a separate tracking number once it leaves their warehouse, and the shipping time is pretty much the same. I however may have some hands, i can list them on ebay for only the postage charge and this way ill ship using the GSP, which probably be like $7. what is the size of the movement? If i dont have them i can send a link to some ebay listings
not sure but is a traveler and i believe a 16s.the dial is 42-43mm.
That should be either a model 1908 or 1899. There are few differences between them, and I'd guess that the hands are the same. Very common movement. I believe the Traveler, mostly a gilt finished movement, was made for export, with most being sold in Britain. Good luck.
I just thought of the fact that I may have seen "Traveler" marked on 1888 models as well. And I just verified this in "The Complete Guide to Pocket Watches".  If yours is an '88 model, I hope you have a case for it. Like the '72 model Waltham, they take a special case.
If you can provide an image, or at least the serial number, from the movement, the model can be determined. Cheers.
Edited by MrRoundel
yes get the serial number and look it up on pocketwatchdatabase.com. its not always accurate but it will let you know the model, size, and will show images of the movement and cases as well. i have the official waltham pocket watch ID and price guide from 1976, which is 100% accurate. so get that serial # and post it
Edited by saswatch88
Yes looked it up. It's a 1908 movement
8 minutes ago, saswatch88 said:
Thanks. Will give it a go. B
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
