Hi All - My Omega Seamaster Mark40 ref. 3520.50 is over 20 years old and need servicing. It loses over -26s per day. I decided to remove it from watch winder and not create unnecessary wear of jewels.
Should I send it to Omega for servicing or to an independent ? (I live in the US)
Thank you... AJ
Thank you... AJ
GOod move to remove it from the autowinder. I think you mean the Speedmaster Mark 40? Mechanical chrono service by Omega is $750 and add $200 bucks if its a precious metal case. I can provide a excellent watchmaker in California (considerably more affordable) that I know, but you'll have to send me a message if you want the contact info.
J
Yes, I meant SpeedMaster, appologies for typo. My Omega is in very good shape externally, I only need an “oil change” without all the frills. But I also need the watch to be regulated to be most accurate possible.  Although Ibthink this is what a watch service is all sbout.
I live on the East coast, would you have someone closer to me ?  Will send you a PM tomorrow.
I was even considering sending it to Mark in the Uk if he does this type of work.
Thank you... AJ
If you have a reputable watchmaker near you and undertakes the work himself on his premises, go to him and ask his advice, it won’t cost you so much as sending it to Omega.
@noirrac1j : I was not able to send you a private message, email box told me you could not receive PM. Maybe a bug I suppose?
Could you send me information directly ?
Much appreciated... AJ
