Seiko 7002 Loosing Time
Thank you for this suggestion. Got to do it: The first slipped, the only way to test the second was to swap the barrels around, it also slipped when wound manually. Left them in that configuration, put the idle gear/ Ratchet Winding wheel/ intermediate wheel back in place etc and, while it's heavier, both appear to slip 🤞 Thank you, everything here was great help
If was lucky enough to find an almost complete tap/die set in a lot. The 8mm 030 dies are really tiny, but the small taps will also require a really (!) soft touch.. 😉
Thanks. Could I trouble you for a suggested alternative to uv glue?
