Pin Pallet Watch Service
Hi Friends.
I’m a newbie, just completing the BHI Tech Grade, exams in a few weeks.
Just come across a pretty but not expensive pendant watch that my partner would love me to service.  It runs for a while when not cased and not moved, stops when in case.
It’s a pin pallet and I’ve heard these are not always the best to service? But want to give it a shot if only to learn and get it up and running for my partner (accepting it probably won’t be the best timekeeper).
Can anyone possibly offer advice or does anyone have any documentation for servicing pin pallets in general?
Thanks so much for your expert help as always.
Pictures attached.
Bethanimageproxy.php?img=&key=77f0dcc5ac0f9d5bimageproxy.php?img=&key=77f0dcc5ac0f9d5b
UNOFFICALLY.....you could do this. Remove from case, reinsert stem. remove dial and hands. Immerse the movement in Naphtha, fully wound , it should run while immersed. let the movement wind down. remove and let dry.lubricate moving parts with a  synthetic motor oil.  just a very light touch. , don"t get any on the hair spring. No, it's not "proper".proper service would involve a total strip down and cleaning of every part. But as a novice you might not be prepared to do this. it can all be done with a decent screw driver.The economy set from esslinger isn't too bad.  ONCE AGAIN.. I reiterate..it is not the proper way to do it.but it ought to work for you.
Edited by yankeedog
content
  • Similar Content
    • Welcome to the forum, enjoy. I have a varimatic that went  out of sequence because it’s hydronic oil ran very low. Must admit it’s still in my garage just know time to fix it. Purchased a cheap Indian Junta/ sonic Pearl as a stop gap a few years ago and it still performs perfectly so no incentive to fix the Varimatic.
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Recently purchased a L&R Varimatic knowing that the piston does not fully rise in the cylinder. The likely cause is air in the system. The manual calls for using a bleeder cup, which is as rare as hen's teeth.Does anyone have any experience with this issue and if so, how did they resolve it?
    • Thanks ww, its maybe not as much of a bodge trick that i thought it was.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  It would be nice if you told us a little about yourself.
