Service of a Seiko 6106 Movement
Sorry I have been slack posting movements I've serviced at home, but work has been busy, and the movements I've been servicing are not that different than what I've already posted ... just more of the same.
Well, I got another one of my Mum's friends who asked if I could repair their watch that was given to him on his wedding day by his wife: who has now sadly passed away :(
Of course I said YES!!  And it turned out to be a lovely old Seiko; but a little worse for wear :unsure:
The hands had fallen off, and the plexiglass was so scratched you could hardly read the dial.
After opening up the caseback, there was evidence of corrosion starting to set in ... but thankfully it was caught in time.
Here's what the intact movement looks like.
Once the automatic works were removed, it was obvious this poor old thing has never seen a service since it was purchased in 1974.  Very dirty, and very dry.
This movement has a complex keyless works which included a pusher for rapid date change, so before I started removing the dial side, I pulled the Balance and Pallet Fork ... just to be sure to be sure :)
Notice how dirty the movement is from this angle as well.
Ok, on to the dial side, to remove the calendar work and the Keyless work.
Calendar work is pretty much like all Seiko's ... minus that annoying phillipshead screw, thank the Lord!
Here's a picture of the Keyless work, with the incorporated pusher system for date change.
More of a close-up of the pusher arm
There is also a large spring for the pusher mechanism
Once that was all disassembled, it was back to the Train Gears and Mainspring.
Notice this movement also has a hack that stops the Train Gears; instead of the Balance ... all very interesting :)
And for my good mate Bob ... here's the picie of the Automatic work mate :P
Look how dirty and nasty the Eccentric Bearing is ... Ewwwww!
Here she is coming back together after a long bath in the suds
Lookin much better!
I polished the case, and spent about 15mins with Ploywatch trying to polishing all the scratches out of the glass ... but it was just too far gone :(
Still at least you can read the Dial now :P
Off to the Timegrapher and in typical Seiko fashion, once cleaned it purrs :D
Hope you enjoyed this post, and I'll try to post more often guys.
Good to here from you again Lawson, especially with another well illustrated post. I'm really glad that work is going well for you!
Excellent post as always Lawson, me too am glad work keeps you busy and in heaven! We were already missing you!
Thank you for showing me the automatic assembly...and the excellent pictures of the whole process! I believe this is one of the most outstanding results -- as seen in the time grapher -- considering the age of the movement. As a coincidence, I ordered a bunch of those from Ramon in ebay and will soon be following track, trying to make work some of them.
As a side note, since they are not runners and some have an issue with the hairspring (missing, broken, twisted, etc) I was wondering if there is a way to find an equivalent hairspring to fit in the balance wheel and how to go about ordering it. If you have any information -- or any other member reading this -- on the subject/process/how to, please let me know or create a new link. it will be deeply appreciated.
Cheers,
Bob
Nice one Lawson, very well presented as always.
Bob,
Good idea about the hairspring, although I will have to get yet more kit to fit one. I have a 6106-8240 in grade A nick & a 6106-5410 (my Dads old watch) with balance issues. Managed to track down a second hand balance (no NOS to be had) but was still being a git & has been on the back burner for a while. The balance is listed as part No. 310.611 but I am informed that 310.614 will fit, Stefan AKA scillachi61 on fleabay has some  & have just ordered one(not cheap unfortunately, but that's the price of hens teeth). Will let you know how it works in due course.
Cheers,
Bob
Hey Bob,
For Seiko spare parts I use "speedtimerkollektion" on fleabay.  His prices are very reasonable, and if he doesn't have the Seiko part you need listed, just send him a PM in ebay and he normally has it in stock.
Hope that helps my old friend :)
noirrac1j, on 01 Dec 2014 - 12:21 PM, said:
Fantastic post Lawson, and excellent work on the Seiko. What oil/grease do you use for the autowinder?
JC
My oils at home are a little limited ... D5, 9010, 9501, 8200, 9415, and silicon grease.
This is what I used ...
On the Eccentric Bearing - D5
On the jewel for the Pawl Arms - D5
On the Pawl Gear pivots - 9010
It seems to have done the trick quite nicely.
Also if anyone is wondering why there is a rub mark around the outer edge of the Base Plate and the Mainspring Housing, that is the sign of an Eccentric Bearing failure.  It's still working in this particular watch, but it's being to foul and will have to be replaced ASAP.
Just thought I'd add that little note to help others in their fault finding.
  • 10 months later...
  • 2 months later...
Didnt realise that hacking is also found on 6106.
Thoughts only on the 6105B.
that is why this is such a great movement. i have 7 of them and can't get enough. now, i only wish it was a hand winder, too.
  • 4 weeks later...
  • Similar Content
    • Ive asked this at a Seiko forum but I know there's plenty of experience here too...   As I have it the recently discovered servicing technique on these is that you stuff the crown full of gaskets and work it until the recessed washer pops, remove the washer, switch the gasket out, dish the washer and push it back into place, levelling out the washer in the process? First attempt did not go to plan... I tried using a plastic pusher to manipulate the gaskets in the crown... Wasn't strong enough and I was struggling to even get the gaskets in up until it broke.   Rethink consists of making/using actual tools: I don't have a staking set, so I've got the old man fashioning a metal pusher, essentially a 2.45mm OD tube with 1.6mm ID with a 6mm press the other end. Also got him on a dishing block/conical stake (sorry I'm terrible with terms) and a holder for the crown while I'm working on it...   I figure that's enough to do the process described above? Push with the metal pusher, dish the washer with the conical stake, press back in with wider flat press (drilled centre so it doesn't catch on the tap).    Plan is to stuff, press by hand and repeat? If that doesn't work by hand I've a drill press I could attach the pusher to for a little more leverage if needed. (Obviously I don't want to go too mad with that, and hopefully can avoid it altogether...)   Sounds like a plan? I'd welcome any advice here, since I really don't want to wreck a crown. Having replaced all the other seals though id really like to sort these too. I welcome any input/advice from those who have been there and done it... Thanks!
    • Hello and welcome to the forum.  Enjoy
    • You need to be more careful modifying the dial area. How does the bezel/lens fit on the front?
    • Recently inherited a box of my Grandfathers watches, nothing valuable, but some cool and some unique items.  Seiko SQ, my aunt went to Hong Kong in the 80's I believe and picked one up for my Dad and Grandpa. Below are picture, I believe its a 1987 5Y22-8A08. Put a new battery in it and it fired right up! Its probably been a drawer for 20+ years. Looks like he only wore it a few times.   Citizen Quartz 46-9181 with a seven jewel 7961B movement. It had what looked like some moisture damage, and a corroded battery. Swapped it with a 371 but it would only vibrate the second hand. Tried trouble shooting while in the case but eventually ended up pulling the movement out and cleaning with some naphtha and blowing it out and running it on the demagnetizer for a while to free up the movement before cleaning the band and case lightly oiling and reassembling everything. Now its back up and running. Based on the adjustment of the band I believe my Grandmother actually wore this watch, and I made the mistake of telling my wife that. Now its her watch! The most interesting so far is a 72-73 Benrus.  I tried putting a battery in it, but no joy. Ran it on my little tester, no signal from the coil, tried to spin it up. Just the slightest flicker of the second hand. Put some naphtha where I could reach, and tried again to spin it up. Nope. This watch is interesting in that it does not look like the back comes off, there is a window you unscrew to access the battery, a huge SR44. Ordered a crystal puller and will begin disassembly next week.  I was able to find a little bit about this watch though a google image search; BENRUS H010 TECHNIQUARTZ 1972 1st US made Quartz made by Benrus. Using a custom E-block with the step Motor, a power switch and a Moto Chip driven by MotoQ at 32KHz, on modified ETA mechanical movement. https://www.crazywatches.pl/benrus-h010-techniquartz-1972
    • It’s done and the movement feats/aligns perfectly in the case. I stripped off 10mm wide sandpaper and wrapped /sticked it around the pad with double sided tape. I run with 400 grit and finished with 1000 grit. Now I can continue with my build, I’m going to buy a dial and hands. The dial I am considering is a larger diameter 36.5mm than the allotted space 35mm in the case, so I will apply the same ‘technique’ with sandpaper and Dremel/drill. Thank you @RichardHarris123, @AndyGSi and watchrepairtalk community for your help.
