Horologicalsuppliers Co Uk
  • 4 weeks later...
A bit late to the party on this one, but its quite easy to figure it all out.
You can search the "who is" data base for any website & this one registers to jnash he opted out of showing his address but a google search for his name pulls up a result for his blog & if you do a whois for that address you find out where he lives, his telephone number & his email address. all in the public not so private domain.
you have to be sooooooooo careful jnash! lol
I'm so glad you have your "Old" details perish the thought of anyone wanting to know the new ones! you say nothing to hide, but in my view its shady and also against the UK's distance selling regulations
https://www.gov.uk/online-and-distance-selling-for-businesses/overview
I for one wouldn't deal with you with your current website. you have some good gear too. not adding a contact even to a new website is never going to launch it into the horological world as a game player.
Just a view of course.
Fiar point, I didn't really think it was a problem as lots have sold to all around the world, lot more inventory going up as I have time, didn't realise not having a address would cause a problem as one of us reply pretty quickly. Opinion noted and hopefully get it actioned [emoji1]
If you take payments via PayPal your protected against any wrong doing, this goes for the buyer or the seller, so it makes no difference if you disclose your address or not. In this day and age it's impossible to find the address of a lot of online business's on their website unless you search whois or companies house. I don't see it as a problem and wish you luck with your business.
PS I had a read through the distance selling regulations and no where does it state you must provide an address. You have to provide business name and contact details, contact details could be phone, email, fax or the name of your carrier pigeon - not address. A lot of business's these days are run from home and you don't want your home address plastered all over the Internet.
It does not matter if it is in law or not, from a business point of view I believe it is good practice to provide potential customers with information about who they are dealing with. It gives customers confidence, plain and simple.
Jnash is trying to start a business and he seems to be dedicated to his website, I have seen progress on it and it is starting to look good. I wish him all the best and I hope it is a success for him.
I do a lot of online buying for work buying IT parts and stuff.
Personally I always look to see what address & phone number are listed in the "Contact Us" section (if there is one).
If it only lists a mobile I generally give them a wide berth unless its the only option available and then only do business if there's not a lot of money involved.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
