Hello from a Newbie
Thanks for the add.  I am a non-repentant watch collector who has done light maintenance for some time.  I have about 35 watches, Japanese, European and US, with a variety of movements.
I've changed bands and batteries as needed for quite some time, and have done quite a bit of non-watch repair work over the years.  I'm a retired mechanical engineer and so am comfortable with equipment in general.
I'm ready to move on to more advanced watch repair and will welcome input and guidance from the folks here as I learn!  I'd like to progress to a full teardown, clean and oil, and calibration of an automatic, but that's down the road...   Right now I want to build my tools and abilities in preparation.   Great being here!
Hi BigSapphire, you have come to the right place! You will find many very knowledgeable people on this forum who are happy to help you carry out whatever project you are working on. There is a vast pool of knowledge here and these guys and girls are never stumped. Sadly, I am not one of the knowledgeable people! Probably one of the least knowledgeable. So welcome to " the happy factory " :)
    • Next is to drill the screwhole this then provides an anchor point so the bridge doesnt slip around while scribing the shape. A cork lid, a pin and a piece of gaffer tape ( 😅 ) keeps it all in place. The hole is measured from the broken part using a hand measuring gauge. Mark the hole, punch it and drill it off to size. The awkward bit is working out where the jumper should be and the detent positions.  I remember watching a youtuber a while back do this with dividers, so i dug out my old school compasses and improvised a little. This bridge only has one hole and to find the detent positions you need two points of reference, so i just worked the second point from one of the corners, hopefully its near enough. Then scribe in the jumper using the two detent positions ( wind and time set ) that were marked and a big picture of the complete spring to look at that helps to give you a feel of where the jumper should be.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
    • As  I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
    • Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing.
    • Thanks again, Marc.  Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts?  Mahalo. Frank
