My quartz project went wrong!
eezy
I have a nice case and dial so decided to make a custom watch for mrs eezy with a new Miyota module.
No dial feet so I used sticky dial pads. I put it all together, it worked fine and looked good so left it on my bench for a few days with the back off. Eventually decided it was OK, put the back on and presented it to mrs eezy. It ran for about 24 hours before it stopped so I reset the time and ran it for a day or so. She wore it and it stopped again.
So further investigations and I find if I hold the watch vertical and tap it, the hour hand moves. The hands are new and not loose so I start thinking.
Conclusion:- The dial is not flat, it's convex, but the module is flat meaning the edges of the module are touching the dial but the hour wheel has a gap above it allowing it to jump out of mesh, even though I inserted the wavy washer.
Ah well, a novice error I guess :)
7 minutes ago, AndyHull said:
Can't you simply shim it with another washer?
Yes but those washers are so thin that 1 won't make much difference.
I've since had a thought that I could put another wavy washer on the other way up and that should work. I could shim it with anything but it's about calculating the size of the gap.
Hi  unfortunatly shimming in this case will be a matter of trial and error to achieve the correct gap. Try putting a bit of rodico under the dial then fitting it then remove dial and measure the thickness of the rodico after being squashed you will be near the size required
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
