Info on Orient movement please
Thanks yankeedog.  My wife’s from NC and would question your moniker.  Being from Boston, I would not.
Advertised as not running but I found a dial foot screw stuck under the escape wheel.  So, I have hope.
 I’ve also posted a question about a missing part.  Any help is appreciated!
Charlie
I am a refugee.I escaped from NY .I didn't have to apply for asylum or anything.I love it here, it's like a different country that uses the same money. I am out in the country. The only traffic here is an opossum crossing the road  in front of you. I will look for that  parts post.
  • 2 years later...
Resurrecting this thread because i have some thoughts. I think maybe there are movements being associated with Orient that they maybe did not make?
Starting with, one of the first watches i bought for restoration has a movement marked "11Y 2M8"
It also has a shield with what is surely a Q in it, but sometimes looks a bit like it might be an O in a shield, which would make it seem like maybe it was Orient. I sure thought so at the time.
I don't have my own pictures handy, but here's pics from a recent auction. Watch is called "Competition I" and seems to be of a series of watches. They all have checkered flags on the dial, the Q in a shield on the movement. There's also "Competition II" and "Competition". They came with various movements and sellers variously say they are from japan or switzerland but i don't believe the dial is actually signed as such?
The 11Y 2M8 bears a striking resemblance to a Förster 152:
 http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&Foerster_152
There's an 11U 4B8 model that is sometimes marked A-201.
"Competition II" is an automatic sometimes marked "12B1D" and "QWATCH", sometimes "12B1D8"
I have no idea who "QWATCH" was.
    • Bringing this old thread back to life, as I have similar problem. I did follow this advice, but while inserting a male stem (crown side) and just pushed it to the female part, and the fork (female side) of the stem has broken. What is the right way? Push the stem part so it widens the gap and fits in? Why it was then receiving side got broken? Old metal? It is a vintage watch from late 60s.    or the outer part should be inserted somehow from the side (slipping to the gap), but I don’t have space there for this manipulation. The watch is Orient Fineness monocoque case.   thank you!
    • Thats insane Nev that you cut those tiny pinion teeth with a cutter you designed and made.
    • I certainly do Razz. Ive just started work on this AS554, interestingly enough it had a paper dial made from a postcard , look at the brand name on the dial, very curious.
    • [SBGA405] Grand Seiko “Godzilla” Spring DriveI always enjoy coming back at the end of the week to my first Spring Drive watch which is a combined automatic mechanical watch and a high quality quartz — a Spring Drive.Impressive accuracy (10 seconds per month) and wears remarkably comfortable at 44.5 mm in diameter and 95 gm.Love the power reserve indicator, and the colour of the dial amd the watch band.One of my “perfect” watches!!😍
    • Yep, so we got a 10 1/2  ligne movement, thats the starting point now these bad boys books should hopefully get us across the finishing line . Next we need a good clear picture of that rocking bar, the setting lever and the setting lever spring. I've already got an idea what it might be.
