When you have installed the hands checked everything is ok and the watch is now ready to go back into the movement. How do you remove the crown? it needs to be turned over to be removed, but now you risk the hands and dial being damaged.
Currently I have just been flipping it over and placing it gently in a movement holder, makes me nervous I’m going to damage the dial one day though. Any tips to guarantee the dial won’t be marked?
When working on a chronograph if you don’t get the centre chrono hand (mounted on top of minute and hour hands) completely central and need to remove the chrono hand to fit again. What do you do? Remove all three again or carefully try to remove the top chrono hand?
I’ve tried using the small horotec levers to gently prize the top hand away alone, but this means applying some pressure onto the minute hand. Must be a better way?
Looking forward to hear how you experience guys get round these simple (when you know how) issues [emoji846]
I can't answer all of your questions but I can help on one. When flipping the movement over to remove the stem and crown, use a plastic movement holder such as the Bergeon 4040-P. I've never marred a dial with one of them. Some movements have a plastic movement holder which relieves you of the need for the above step. Most notably the Seiko models. The last time I installed a sweep chrono hand off the mark, I chose to remove all three hands in order to correct the problem so I would like to read responses on that issue as well.
Yep also using the 4040-p [emoji1303] I’ve been through loads of marks videos and it always seems to cut short at this point, like no one is interested but I really want to see what he’s doing [emoji23]
Maybe is stupid but i use my teeth. I hold the movement with my left hand. Press the setting lever with my right and pull the stem out with my teeth as a third hand. Hold my breath while i am doing it. Has worked so far.  Use a latex glove on my right hand  if the movement is finished and is about to be put back into the case.
Edited by rogart63
Being a novice I get Mrs eezy to pull the stem while I'm holding the other bits. Not very professional but I know my limitations.
I  take all 3 hands off. If using new hands or movement, I find they go on easier second time around.
Would these work for the chrono hand? Looks like they don’t need to touch the dial so could carefully pull up on the hand without touching anything else?
Depends on the movement. If i have a specific holder i use that . Have such for the valjoux and seiko 6139.  I can hold the reset button in while i center the chronograph hand.  I test some times before pressing all the way down.  Have not worked super much on Landeron  movement but some has a three piece case and you can put the hands on when it's in the case. Making it easy to hold the reset button in .  You didn't say what movement you are working on?
Hi Rogart, that’s very interesting thanks.
I am getting to grips with the 7750 and I also have a clone 4130 movement.
I was also wondering why you hold the reset button down?
Everyday is a school day here [emoji3]
53 minutes ago, AP1875 said:
you have to hold the reset button because when the button is depressed and held, the hammer is pinned up against the chrono wheel hearts thus holding the reset at exact zero while placing chrono hand on. if you dont do this your reset will most likely not reset to zero. also never did a reset on a 7750 but i have done it multiple times on seikos. I know seiko 6138-6139 for example has a faceted (D shape) chrono wheel pinion, so if you place the second hand down and its wrong, you will have to remove the hand and broach the hole or again, it will never reset to exact zero, and you only get 1 or 2 tries before you cant broach anymore and then your looking at a new second hand. I have a specific movement holder made for reseting seiko chronos, and i they are available for the 7750.
also those pullers you pictured are for curved dial you need the 30637-2, or bergeon does have and hand remover specifically for chronographs (5060) and its only a few dollars more than the 306 series pullers.
as far as turning movement over to remove crown you can get a movement holder specifically made for that movement, or get the bergeon 4040 however esllinger has one pretty much exactly the same for half the price. when you reverse the dial place a little ball of rodico on each point of the movement holder that will make contact with the dial. Or you make your own out of a block of wood, you can even have someone 3d print one for you. I make my own movement holders esp for my chronos so i can reset them, i takes measurements and build them in a 3d program then 3d print them.
you h
Edited by saswatch88
Hmm I have never heard of this before, however my experience is fairly limited. Thanks for sharing and explaining in detail. The only way I learn is from here and youtube. However I have never seen Mark do this is any of his videos.
So can you do no harm by pressing the chronograph buttons?
I've always been careful no to press them in whilst no hands are mounted. I have the AF 7750 movement holder, so will try the method above..
You cant do any harm really, but when you hold the button down while setting the chrono hand there is no need to press down too hard that may cause damage to the recording wheel hearts. Just hold it firmly but dont over do it. there is a hand setting press on ebay that is only $13 this helps keep the chrono hand steady while holding down the reset button. trying to hold down the reset button with one hand and then using other hand to grab tweezers, place the hand on the pinion, and then press it with a hand held press without making it move off zero can be tricky. the hand press helps with that, and is an overall good tool because even when putting hands on in a normal situation it will allow you to press hands down so they lay parallel with the dial.
Should you hold down the reset button with all Chronographs? If it’s not going to cause any harm.
Yes I’ve found it very tricky sometimes to get the hand to stay pointing to 12’oclock this is what prompted my question about removing the chrono hand. I have done it on occasions straight away. More often than not I find it slips a tiny bit, on this occasion towards 11’oclock everytime, it made me think is the pinion the hand is on actually round. When I finally set it correctly I ran the chronograph and it didn’t reset to 0, slightly off towards 1 o’clock, which why I’m very interested in this subject [emoji851].
I have a press like this
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
