Main Spring Question
bjd1020
I have a barrel for a 7750. After building up the movement it seems as though the main spring is "slipping". When I wind the watch I can feel the spring tension build the I get a click and the tension releases. I opened the barrel and had a look and to my novice eye things look fine. Normally I just buy a new barrel as they are relatively cheap. I have watched a few videos on spring replacement. Is this normal? Did something just come loose? The arber inside the spring looks like it just has a catch that when its turned it catchs the spring. Im guessing this is designed to slip to prevent overwinding however its slipping after two turns of the stem. Anyway. If anybody has any insight id appreciate it. Thanks.
Sent from my SM-G950U using Tapatalk
No you can't use Moebius 8300 for the barrel wall. The recommended braking grease to use for ETA 775 is Kluber 125P, which is expensive. I have used Moebius 8213 for Omega, and if the barrel is aluminum, then use 8212-SC for moderate braking. The mainspring on the 7750 is quite stiff and thus needs a strong braking grease.
http://www.moebius-lubricants.ch/en/products/greases
1205814176_ScreenShot2019-02-28at1_47_02PM.thumb.png.0a94f7d1ecc85ce2a62d40c378a818c1.png
Man its a lot to learn. Just when I think Ive got ot down a whole other segment of learning appears. These movements are like machines built with multiple little machines. Thanks for the input.
You're welcomed. If you need a little braking grease to finish this project, I can send you a few cc's in a zip baggie and mail it to you. PM me with your address.
J
J
That is very kind of you to offer. Ive spent a lot on lubes lately. There are awesome people in this world after all. Thanks for reminding me of that. If you only knew. Lol.
My pleasure.
J
    • Couldn't see it on the tech sheet , picture is a bit fuzzy though . Is that to keep the pinions pressed on Marc ?
    • Doctor, If the train turns when hands setting, this means that the train is not blocked. And this is true for all kinds of trains design. The train is normally blocked by the lever. So, put the lever in place and try again. If the train turns again, search where You have placed some wheel upside down and it is not meshed with the next one in the chain. The other thing is the amount of friction that is needed to overcome when setting hands. Yes, the friction part here is in the great wheel, and it needs lubrication. If the parts are dry, then friction will arise, seizing will happen and thus risk of breaking of teeth in the train or breaking of joint wheel/pinion. I don't know this calibre, but I guess the clip is part of the friction device. But for sure it stays tilted, which is not normal. So, pay attention to it and see what is wrong there
    • It most certainly should be there, but it should fit better than that. Here is what it should look like.
    • This way is dangerous. The problem is that the collet is not expected to be perfect in this tool and the wheel used for the grinding is big and easy can touch the balance wheel. Can You show the bottom side of the balance wheel?
    • It shouldn't be attached    The pinions look independent of each other, not in alignment,  but the clip is bothering me or have you just placed that on the pivot end?  Found a cannon pinion maintaining clip in the tech sheet, is that the disk on the end and is broken.  Whatever happened to exploded diagrams 😠
