Replacing broken pivot.
It's a spare from another watch. It's 0.5mm Dia. spring steel if you want to make one.
Thanks Andy, much appreciated. Was that one you made or pulled from another watch? Assuming it's one you made what's the diameter of the wire? Thanks once again.
By SwissSeiko · Posted
I use an old oiler that is bent to a similar shape. I also just go in through the spring while its attached to the cock still. wristwatches can be tricky -
I recently converted my Seiko NH34 to a manual wind by losing the rotor screw. if anyone has an extra one could you please let me know Thanks for your consideration, Dave
