Swatch
I own this swatch irony , was winding the  correct date on this Watch and it stop working............. there are several possible solutions to fix this problem but I do not know how to get the bezel off.............. researching the problem I found that swatch watches are not intended to fix..........I did not know if this is true or not , so I decided to ask the professionals about this................ can a swatch irony be fixed and how?
I have one in my drawer, that a friend gave me not working and which is waiting since a few months.
I'll try to make it work so I can give you an opinion.
Envoyé de mon Moto G (5) Plus en utilisant Tapatalk
Swatch branď laser seals some lines of thier product, Generally using odd calib mechanical movements in such lines, for which  producing spare parts defeats the original idea.
 If you can get your hands on two or more of such non runing watches, you got your own spare parts inventory and can repair. Providing you like this idea and decide to give a try,  look into polymer cases as they are easier to cut through to get the mivements out.and best to house your reconditioned movement in SS cases.
Cheap Asian made swiss watches for life.:lol:
Not to hijack this thread but I've looked at several Swatch models with mechanical and quartz  movements and yes, they are indeed designed to be "disposable". Either by being sealed in such a way that the watch is destroyed or damaged during disassembly or by not producing spares. What in the world could the Swiss be thinking? In today's world, sustainability is a real issue, not just political rhetoric. I'm undecided if they are being stupidly arrogant or arrogantly stupid about this matter. I wonder if the buying public truly understands that these watches are disposable when plunking down their money?
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
    • There are some parts on Ebay for the seiko 6020A, it may just be a waiting game for someone to strip one down, NOS will be more scarce . K would strip your movement down to the module then start looking at other seiko movement to see if that coil is used, then seek out a seiko part dealer. Also Retrowatches youtube owner Mike may give you some advice try him on his site . He also hangs around amateur watchmaking groups.
    • I would agree, in order to work harden something you need to exceed it's yield strength when it moves from the elastic zone to the plastic zone and you get permanent deformation and work hardening which is fairly close to its failure point, relatively speaking and dependent on the material/alloy of course. In theory you can load something constantly within its elastic range and not suffer work hardening issues.
    • Probably easier to get a complete new movement - but CousinsUK list it as discontinued. Maybe someone on here knows a substitute movement ?
