Timex Time Machine Restore
JerseyMo
It all started with an inquiry if I had a replacement dial for a watch that had suffered a leaked battery.  Knowing it would go far beyond just a new dial, I offered a trade for the remains of the watch.
Replaced dial, NOS movement, NOS circuit board,  detent spring, repainted dial ring and now I am only missing one of the original Time Machine series. (second from top)
Once again a really nice job !!! you're really good at what you do :Bravo:
About the one you miss (second from top) and looking as the close-up pics below, I'm 99% certain it's possible to build such a dial with clear decal on a white or off-white spray-painted dial plate.
These days I'm building an hommage dial based on a 980.016 quartz Heuer diver from the 80ies.
I take pics on every stage of the making so I'll post a tutorial explaining all the process, from the blank dial plate to the finished dial.
I'm confident the same method could be used to redo a Timex Time Machine dial (the only difficulty will be to put a flat decal on a domed dial plate ... but I know that is doable as I have already done that).
The dial is not the so much the issue, rather it is finding all the other parts.  Most difficult would be to find the circuit board.  I had one in stock and it came from a lot I bought 4 - 5 years ago.
I am curious about this decal method, how do you go about making one?
As I said in my last post, I'm building an orange diver Hommage dial those days, just for the purpose of shooting pics of every stage and writing a tutorial ... and for the fun of it.
I still need 3 days to finish the process (only 5mns a day but hours for drying) so I'll create a thread about that on Thursday ... Friday the later.
Envoyé de mon Moto G (5) Plus en utilisant Tapatalk
Here is a step-by-step "custom decal dial" tutorial
    • This is not rare at all, the dial code and case code don't usually match.
    • Good question!! Anyone know of a substitute movement??!! 🤔🙏
    • Interesting issue that I just noticed: this Seiko 5actus Watch from 1977 has a calibre listing on the dial of 7019-8030R but on the case back it says 7019-8010!! Like a mis-printed coin, is this watch therefore worth a lot of money for its rarity?? 🤪😲🤔🤪
    • I wish that was the case. The Aegler movements used in the early days by Wilsdorf & Davis (for brands like Rolex and Rolco) came in several sizes and without designated calibre numbers that survive.  They become a bit easier to identify during the 1920s. Below is an Aegler-Rebberg, 25.74mm in diameter. It’s from a woman’s Rolex wristwatch. Stamped Rebberg and 500 on the dial plate (but it isn’t a Rebberg 500, it’s the wrong size).  I’d be interested if anyone can identify the movement.  It is based off the Aegler Nr.1, circa 1903, but they based many many calibres of different sizes on it. The closest I have to a positive ID is the  ‘Rolex Nr.50’ circa 1917, but no dial side images or movement sizes are available in the references. There are identical looking movements in many sizes.  The 25.74mm of this movement is a particularly strange size for the era, it equates to 11.41 lignes.      Best Regards, Mark
    • It looks like this movement comes with a number of different shock settings. Emmywatch shows that it comes in versions with no shock settings, 'Incabloc', 'shock resist', and 'Supershock'. Perhaps the different settings position the impulse jewel/roller table in a non-ideal position relative to the pallet fork/guard pin. Are you able to check under high magnification if the pallet fork and roller table are able to operate without any interference? Just for fun I took a look and I have one FHF 70 in my collection, a West End Secundus with a non-shock protected FHF70. I had a note with the watch that said, "Movement is stamped 'FHF 70', but the FHF70 looks to have sub-seconds instead of center seconds movement (??)" but that a google search turned up both types for this movement. EDIT: I just took a look in my parts drawer and I have a few of these movements, both in center seconds and sweep seconds, but they all are non-shock protected.
