im beginner for watch
difficult for me
 7 ~8 differnt screw looks like same screw with loupe
let me know how to .....
the answer is many experience for watch?
is it easy to know this ?
watch parts name (english korean )  is difficult for me because im korean
  im disassemble sellita sw200-1again now
Hi Alex,  Not all watch screws are the same, When dismantling a watch keep all the screws associated
with the part being removed together so that they will go back when ready to do so, Although many screws look the same there may be sublte differences,  thread pitch .... thread length....head size.  These differences may all be associated with one watch so that is why it is inportant to keep associated parts and screws together to avoid problems.  There is no substitute for practise, read the books and watch the videos.  Mark Lovick a contributer to this site and professional watch maker has some very good tutorial videos on U Tube which are excellent for study purposes,    enjoy  cheers
If you are unsure about dismantling *anything* including a watch, then take pictures, or a video as you go along.
I also tend to put the parts from each step in to separate compartments in a compartmentalized tray.
So the first screws I remove go in the first compartment, then the next bit I remove in to the second and so forth. Re-assembly becomes a reversal of the dismantling process.  Start from the last compartment and work back to the first. I've been using this method since well before easy digital photography with a mobile phone was possible, and it is a good habit to adopt.
It is very easy to get screws of different lengths mixed up, and in a watch or clock (or indeed any other machine) this can cause damage, or result in the item not operating.
Edited by AndyHull
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
