I have seen that symbol in westclox branded watches with Japanese movements.My guess is seiko.Once upon a time they sold movements to other manufacturers.
Edited by yankeedog
content
You're in the correct area yankeedog. I'm not disagreeing with your superior knowledge but I'm posting a photo of my Citizen ProMaster. The logo is on the crown and while not an exact duplicate, it's close.
Edited by TexasDon
Yeep! Yankeedog you are definitely at the top of your game. I needed to look at one additional frame before making my prior post. It is indeed a Westclox with a Seiko movement, circa 1960's.
