2892 Remove mainspring power
To All
I purchase a  clone 2892-a2 ..I have seen Mark's video on servicing it also his one servicing the omega with same movement . When I try to remove power from mainspring  by pushing the click spring out of the way I feel the stem  unwind a little also see the ratchet wheel move a little but the barrel does not and there is still plenty of power left ...What can I possibly be missing?  In The meantime I am just waiting for it to power down ..But I would like to know for future reference.I probably should assume something is amiss.
Thank You
Anthony
PS ...This movement looks like it is going to be much more challenging  than anything I have tried so far. Any tips appreciated
Edited by adiorio110
So my apology when I looked at the tech sheet I knew the automatic came off that standard but I thought it had a standard click mechanism not quite. Mark actually has several videos I found another one at about eight minutes 40 seconds he shows releasing the click. Then just to make sure from your image I circled where the click should be. Then image from the tech sheet to see the layout of the gears etc. part number 425 is the click.. So as a guess if they gear train is glued together with gummy old oil and that would include the stem winding parts it's not going to release. You may be able to back wind from the crown  if the parts will move at all.
Then worst-case  not my favorite remove the pallet fork. Make sure  the dial side components are off when the train spins down  you don't want to have anything to come to a sudden stop that would be very bad.
https://www.youtube.com/watch?v=L5M4WFJ359c
JohnR725
Its a brand new clone movement so it should not be all gummed up. I Looked at the video you attached it shows mark was helping the barrel along by unwinding it.  I was expecting to be holding it back from spinning to fast. If it still has any power tomorrow when I make another attempt I will try that.
Anthony
5 hours ago, vinn3 said:
if you remove the balance and fork it should let the spring down and this allows you to "run the gear train for inspection.  vin
Vin
Thanks JohnR suggested the same thing..As I am new to this movement I think I am going to just wait till it powers down ...I don't want parts to go flying all over the place.
11 hours ago, adiorio110 said:
Vin
   check it out,  that is a way to let down the main spring.  ask Mark.    good luck.  vin
I took a shot And it worked find ...Thanks
Took the whole movement apart and rebuild was pretty easy ...Think I should try a 7750? or is there something  a little more complicated I should try first
    • Just got these good quality diamond files from the bay for Just a fiver, we all love a bargain dont we. Brand names are J.K.Smit  and Triefus, two old diamond tool makers so not cheap crap.
    • Its a touch under ive just remeasured it and added a wrist shot. Unbelievably it was £13  plus 3 postage. You dont find watches that nice for that money every day of the week. Maybe removing the epilame in the oil region improves the purpose of it. We may know very soon as i emailed Episurf 4 hours ago to ask that exact question. 🤞they are happy to provide an answer for us. How do you fancy trying a stearic acid vapour treatment experiment  H .  Shall i have a go this afternoon ? Stearic acid experiment underway,  its started to melt at around  65° C. The idea is to find a large cap jewel to suspend over the vapour release.
    • That's the size of my grandfather's Ernest Borel watch. Definitely not a lady's watch! 👍
    • Thanks H It does have a big crown for the watch , it could be considered a ladies watch these days i guess, it measures 33mm case 36mm with that large crown 18mm lug space. A tad small for a guy of today, but still very wearable. The photo was deceptive so here it is adorning my 7 1/4 " wrist. It need some love to make it run better. The hair coils are touching so running a bit fast at the moment,  not caused by magnetism, and maybe just a clean and a service. The dtal is in fantastic shape.
    • That's one beautiful timepiece! Love the big crown in proportion to the case. Perhaps a ladies' watch, but I don't think so. I have a "modern Ingersoll" watch, but it has nothing to do with the original brand (Miyota 9015 movement). Interesting synonym for synthetic oils! 😆 There is, of course, a limit to how large a volume of oil epilame can bind and hold in place. If the oleophobic effect is too strong then it can become a problem. I'm not sure where I heard or read it, but as I understand it, the active ingredient in a bottle of epilame is extremely small and more than 99% of the contents of the bottle is just a transfer agent. If the active ingredient becomes too concentrated, which it can become over time, or if the product is of poor quality, the oleophobic effect is amplified. This in turn causes the applied oil to look like a gummed-up ball on the surface of the treated part. If that happens, we know that the active ingredient has become too concentrated. What we want is for the oil to bind but not to the point where it is formed into an excessively round ball on the surface. The highlighted text in the patent that you refer to describes well the problem that can arise with too high a concentration of the active ingredient. However, I would be extremely surprised if the entire amount of oil leaves the treated surface as water on wax would. At present, I am convinced that the analogy between wax and water on the one hand and epilame and oil on the other is incorrect. Epilame is described as binding and that is also my absolute experience. Epilame probably has some repelling effect but that is not its main purpose and that is not how epilame is designed and works. The method of abrading the epilame treatment from the section of the pallet stones coming in contact with the escape wheel teeth seems after even more research to be well established, but if it actually works, if so how and why is beyond what I can currently understand. Perhaps it is just to do and trust that it is based on well-established experience. I am, after all, inclined to think so.
