Seconda case back.
HSL
While waiting for a good clock project and the rest of the tools I thought to take a look at these Russian watches.
I have a couple but noticed one is missing the back. I have no experience of these beasts and naturally have a question.
Do the ring holding the case back have the same threads on all Russian watches of the same size?
If it is can I take both the case back and ring from a similar and just screw it in place?
Is there any accurate source where one can see which case back fits to this type of case?
The diameter on the threads is 33.6 mm, inside it's a 2427 auto winder from the 2nd Moscow factory.
52 minutes ago, watchweasol said:
Hi    Cousins uk and Gleave & Co have a liberary of tech sheets and also Esslinger  in the states.
Not sure these have parts for a Russian watch case, some movement parts but that is what I found.
34 minutes ago, rogart63 said:
Vostok is only 32mm
thanks! then we can check that one of the list.
    • Hi @Roll1ex, welcome to WRT. Is there a big second hand watch market in Mumbai? I seem to see a lot of used watches and clocks on eBay coming from Mumbai.  I used to buy a watch every month from Mumbai on eBay. My mentor told me it was the best way to learn watch repair, by fixing everything that's not right.
    • Here is another option, if you have the patience to sort through the parts you usually find 50-100 screws as well as some other cool stuff. Most times I get an order from these guys I get a 250g box, takes a few days, but end up with hundreds of spares and all you need is for one of them to be useful and it pays for itself. Also helps hone your tweezer skills!
    • As Hector said they have too much  tension, that tension is also fixed and not easy to control. Conventional tweezers have infinitely variable grip provided by us.
    • Thank you and i appreciate that, it looks very different    Thank you sir but i think there is a little problem according to that reading it's because it is far different to the other move that i serviced, i will atouched the photo. They are different movements but this one is 7s26b movement and they are also different in shape when it comes to the ballance assmebly. Thanks also for the concerned i appreciate that.
    • Donor movement showed up, so I stole the bridge screw from it. Which made me sad, because it's in such nice shape! It seems a shame. Maybe I'll find a use for it one of these days. Unfortunately, the stem is for a different style of case and is much too short. Fortunately, I ordered a brand new stem from McCaw Company. Unfortunately, the crown on the donor movement is thoroughly stripped out (it unscrewed in a shower of brass) so i just put the old stem back in for now until I source a new crown. As you can see, it's just a little too long for this case. Overall I'm super pleased. I didn't think I'd like the bracelet, and even that is growing on me.   Anyone have a favorite crown assortment?
