Well hello everyone i am John...i am not new to watches...just to this forum...i have been on SCWF and Wrist Sushi for quite a while...i have asked around and no one has been able to give me any advice on my latest project....well i am putting a very nice Seiko 6105-8110 back together but somewhere along the way...someone damaged the case tube...and as most of your know...they claim that they are not repairable and case would have to be thrown away or what most people would do is a trip lock...which i personally dislike...one of the features is that unique crown...well i think i have done my due diligence and came up with a good solution...but i can not seem to find the correct way to accomplish this...here is what i am up against....here is the crown tube....
pic is borrowed from a friend on SCWF...this is far as i can tell the only pic of the infamous Seiko 6105 case tube...this one is from the 8000-8009 model but it is same but the 8110-8119 is just longer in the crown side....
here is a few more of what i am looking to build....
well my question to everyone and why i put this hear is ....i have figured this should be able to be made from stainless tubing like the originals and my thinking is that if i had the correct lathe...and the correct inner material to fit inside the tubing...i should in theory be able to replicate these...those who own lathes and have one...please let me know if i am right or wrong?...i have all the dimensions and i think i have even found the correct 4mm Od by 1.6mm Id tubing for the job....tube length  3,8 mm,  diameter outside 2,6 mm. inside 1,6 mm
any help will so be appreciated...
thanks in advance
God Bless,John
sorry for the long thread...
i am going to try and use a modified mini slide hammer assy to extract the old crown tube complete as to have one for measurements and to model the new one after...i will need to make a adapter to do this....
This is a great project.  I've heard that those old Seiko tubes couldn't be replaced but always figured there must be a way if you had the right tools and a bit of talent.  I think someone else did the same job a while back and put together a document on it but I've long ago lost the links.
I did a similar job to a chronograph cases a while back which had stripped out threads for the pushers.  Like you I used stainless steel tubing and turned it down on a watchmakers lathe (Peerless 8mm).  It wasn't too much work but it did take time- the RPMs need to be kept low and a carbide graver worked the best.
well hello and appreciate the response....i figured i can not be the only one thinking about this...i know it would take a little work and set up....but would totally be worth it...might u remember who did this?...i do not have a lathe yet....not really sure which one to buy...i have used larger wood and metal lathe's....never one this size...and never even thought about owning one...but i like to fix things myself and if u have the tools...why not do it yourself...
truly appreciate the great info....carbide bit...low rpm's.....God Bless,John
I have been retired for many years. Back in the 70’s and 80’s you could buy these case tubes for buttons from suppliers, If you bought a new button for the case it came with a new tube.
What you have said and providing you have the tools and skill it will work.
Well thank u for the kind words...i think i need to find a good lathe...that will be key...i think i will practice on some cheap cases...if i make a mistake...better on them than my 6105....any recommendations on lathe for beginners?
God Bless,John
Sent from my LGL41C using Tapatalk
Is the pendant tube threaded inside for the crown to screw down onto, or does it screw against the small stud?
Should be easy to turn on a lathe.
Well the tube is not screwed in nor does the crown screw down...from what i am told..it is press fit into.the case with some epoxy....my thinking it should be something easy for someone with a lathe...i am trying to find a lathe or someone willing to make me a few...appreciate the response...i think i have found the correct material with the correct 4mm od and the correct 1.6mm id...God Bless,John
The crown just is a press fit and that little stud just locks the crown once it is turned...not the best design for sure...but it works...i just want to return it back to how it was originally made...the crown gasket is quite stout and seals quite well...but the tube itself needs to be smooth and made correctly for everything to work as it should...most of the aftermarket parts people try and use will not work...that is why genuine parts and making the tube properly will be key
You shouldn’t have much difficulty in getting someone to do this if you can find the right person. If I had more time then I’d offer to do it, but I certainly don’t.
It would be quite simple to make on the lathe with some rod.
Oh, and remember to make it stainless! Most of the material I work with is carbon steel as it’s more common for clock making work.
Thank u for the kinds words and offer...i know the feeling...always way too much on my plate...God Bless,John
    • Hi all, Might a posit a theory and people can chime in and tell me if I'm barking up the wrong sycamore: If a mainspring is a bit coned and returned to its barrel for reuse, is it less likely to slip when the spring gets to fully wound?  For a bit of background: Slava 2427, barrel walls greased with 8217, six dots evenly spaced around each of the barrel walls, then smeared/ spread along the wall before popping the springs in.
    • What kind of screwplate are you using? The old Martin ones commonly came in B and L variants. The thread pitch is slightly different between the two, and the full thread diameters tend to be a little off from metric nominal, but the B plates are close enough to metric that they work most of the time. The numbering follows (pretty much) the numbering for stems- at least how stems threads are commonly called out. So a "tap 12" would be 0.70mm. (I can only guess the "tap" size for stems comes from these old plates)   These old plates tend to cut some and also form the thread by displacing metal. I think in part because they are low-tech, and also generally a bit worn. So it's good to start quite undersize with your initial diameter, and work up to something that gives a full thread form. There are variances plate to plate too, most likely a combination of manufacturing differences and wear.   I haven't tried any modern screw plates, I think they are of questionable origin, and even if marked in metric, probably merit some experimentation like the antique ones to find a good starting diameter.
    • Exactly. As Richard says, all good - I helped you by splitting your comment made on an old topic into a new topic of your own in order to help with clarity 🙂 Welcome to the forum by the way 👍
    • Mark, means he has made this a separate post, he has split it from the old post. You don't need to start a new thread now.
    • No, my first time. I've watched the video, lets hope it looks as good as yours.
