What is this rotor part for?
Lc130
Hi All
Hoping to continue my learning from last winter (when work slows enough to allow the hobby) I'm attempting a dis/reassembly of what looks to be an AS 1700 in a Sears Tradition.
On the top of the rotor is a bracket (4th and 5th pic) which is held in by one screw with threads.  The other screw (shown) has no threads and just floats under the bracket (see red arrow) is far as I can tell. Removing this bracket appears to have no effect on the rotor.  What is this thing for (floating screw and bracket)?  Notice that bracket has arrows on it.  Why?
Thank you for any help
Charlie
Maryland
Hi @Lc130 - it's always worth looking around the background of a movement and/or the family it comes from.
In this case the history behind Universal Time Corporation (UTC) is that it was set-up by Seiko in order to sell unbranded versions of their movements to manufacturers to build their own watches from.
Ranfft tells us that a UTC 33 = Seiko 6601B so you can instead search around the latter and its family e.g. 6601A ... https://www.cousinsuk.com/PDF/categories/2862_Seiko 2451,6601A.pdf ; 6602B ... https://www.seikoserviceusa.com/uploads/datasheets/6602B.pdf etc. You get the idea!  Good luck! :)
Its a simple way to remove the rotor. Just loosen the screw (the one which does not have the two dimples next to it) and swivel the locking cam. The rotor will lift straight out. It needs to be lifted straight otherwise it will 'jam' , I find that rodico helps. Or you can turn it dial up and tap the case and it should fall downwards.
Anilv
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
