Gel Vs padded cushions
Tmuir
My current order with Cousins is looking a bit small to justify the £12 postage, so I want to add another couple of things to spread the postage a bit further.
I'm thinking of replacing my cheap and not very good padded cushion I sit watch cases on when adjusting them and at looking at Cousins I didn't realise there were so many options.
I'm pretty sure I will end up just ordering a traditional felt padded cushion, but can explain to me why a Gel cushion might be better?
Also do the Gel ones dry out or go hard over time, so in a few years it would need to be replaced as a good felt cushion if looked after should last me forever.
I'm pretty sure it will boil down to 'they are all as good as each other' and its just personal preference, but interested in what otehr people think.
I have a Bergeon padded cushion and it is only about a year old and is a bit battered, the foam has a bit of a memory effect. Meanwhile my friend picked up a gel cushion and it seems a much better job, and has held its shape well.
Sent from my Redmi 4X using Tapatalk
    • OK, let me try and expand on why I think this is right (but maybe misleading at the same time). Wikipedia has a good explanation of surface tension, which is where I got most of the ideas below. The cohesion of the liquid molecules binds them together into the most compact form possible. If there are no external forces acting, this is a sphere. Surface tension is the combined effect of the cohesion between molecules on the surface with others on the surface, as well as the cohesion to molecules just under the surface, causing contraction and the formation of a denser "skin". The way a droplet of a liquid forms on a solid surface is determined by the strength of this cohesive force relative to the adhesive force between the liquid molecules and the surface material. If cohesion >> adhesion, you get a droplet. If cohesion is similar to adhesion, the liquid tends to spread out on the surface and creep away from its original location. Oil doesn't have the same high surface tension that water does, so it is not going to form a really rounded droplet on any surface in the way that water will "bead" on wax. This is where my earlier statement is misleading, but it is still exactly the same principles at work. Drops of oil on an epilamed surface are not going to run off in all directions at the lightest provocation. What the epilame does, I think, is reduce the adhesive force to the surface somewhat, making the weak cohesive force of the oil molecules more effective. The result is less tendency of the oil to spread out and creep, and more tendency to stick together as a cohesive mass. I don't think epilame has any effect on surface tension. That is a property of the liquid and is determined solely by the cohesive forces between the liquid molecules. I also don't think the epilame makes the liquid "stick" to where it is applied. The oil adheres ("sticks") more strongly to a non-treated surface than to a surface treated with epilame. This is why the epilame needs to be removed from the contact surfaces by running dry for a short period. The oil then sticks more readily to the local contact surfaces, where the epilame layer is worn away, than to the surrounding area. The oil sticks together, and is thereby anchored in place as a single body. Interestingly, reducing the adhesion of the oil to the solid surfaces will also reduce capillary action, which is what we rely on if we don't use epilame. Another reason to make sure the epilame is worn away from the spot you want the oil to stay put.
    • Look up index vs free sprung balances.  The screws are for timing.
    • I was considering just building a watch from scratch, I've heard the nh35 movements have a lot of case and dial choices and apparently they run poorly when you buy them new so a good service is required. But honestly building a watch like that doesn't interest me. I love fixing things. There's nothing more satisfying to me than taking something broken and making it work again. Plus watches are cool 😎 and easier to store than a car engine! I only had one engine in the dining room and my wife complained. Hopefully the watches will go unnoticed.
    • Hi all, My "practice" watch has a worn our balance pivot, so I ordered a balance complete. Pieces nr 4871 for Unitas 6310. It's probably no big deal, but my original balance wheel has plenty of screws or similar protruding all around, while the new one I got doesn't. What's the purpose of these thingies? I haven't installed it yet, maybe next week. Thanks
    • For those of you who are looking for a Seitz jewel gauge, I just want to make you aware that there may be a good opportunity right now at Tradera.com (Swedish eBay). The site has significantly fewer visitors than eBay and I have made several fantastic deals there. 1500 SEK corresponds to approx. £110/€128/$137 https://www.tradera.com/item/1922/631487681/seitz-urmakarverktyg-matare Just to make sure, I'm not associated with this listing in any way!
