Showing content with the highest reputation on 05/07/17 in all areas
  1. Had an interview today and wore this for luck. I had this overhauled over the Summer and it is a handsome piece indeed. Month, day, weekday are set..the moon phase...maybe I can count the clicks? Sent from my SM-G920V using Tapatalk
  2. I suggest a pallet setting tool to achieve a good repair. Heat & shellac is used to attach the stone. I have positioned the pallets stones to the same depth and it has worked every time. I use this tool to achieve .
  3. Manuals for Seiko and a few others i usually find here. http://tech.gleaveandco.com/ Difference between A and B is mainly a few springs that looks different and i think the keyless work is different to. Most parts for A doesn't work in B Chronograph wheel is different. file:///C:/Users/admin/Downloads/Chronoraeder%20888xxx.pdf
  4. Welcome! I envy the fact that you have lots of tools to begin with! Best wishes to you.
  5. Here's a couple and then for something a little more affordable (Ingersoll) Sent from my SM-T585 using Tapatalk
  6. Great news - well done! The cheap Chinese timegraphers won't play with cylinder escapements, but in reality you are unlikely to be that worried about missing your train because your pocket watch wasn't keeping good time... S
  7. If you have the time, skill and tools, anything is possible, but we're floating away from buffing vs polishing original question(s), let's agree that is personal preference and restoration of cases can take different processes, based on user experience. Whatever works to achieve desired results. I agree with RCDesign, lapping is the way to go on a square case, I don't have the setup to accomplish this, so by hand with Foredom and different buffs/rouge, I try to accomplish a presentable finish, like you said, not perfect, but close enough.
