Urgos Grandfather Clock
Folkvisor
Hi All
I haven't been here for a while.
I'm working on an Urgos Grandfather Clock. The movement seems to be working fine but the clock isn't free-standing. It's in the middle of a China cabinet and there are no side access panels.
I am tempted to MAKE some with a chainsaw but, unfortunately, the owner doesn't like the idea.
Does anyone have any experience with such creatures?
Dave
Thank you for your answer. Yes it's a modern movement - about 30 years old.
I got it out - took almost an hour. Putting it back in will be even more of a challenge I think. It will only go out the back. I'm hoping I'll be able to fix the dial before putting it back in.
I'm just hoping everything will line up for the chime hammers. I marked everything before removing the movement but it doesn't seem to matter much. I think it's just a kind of hit and miss thing.
But after cleaning and oiling the clock works.
I got it in and it works. It was a LOT easier when I found out it came out the front of the case!!! After doing all kinds of other crap...
Anyway, it's in and working.
But I had a nice level clock shelf for it and it is now on a floor that isn't level so...whatever...
Thank you for your comments.
I found this to be necessary, if you want to find out more about Longcase clocks.
White Dial Clocks: The Complete Guide by Brian Loomes. Any book on clocks by Brian is worth every penny. Watch and clock makers of the world vol 1 and 2 are helpful in dating, comes in very handy if you  have to value clocks but very handy as reference books. Anything by Laurie Penman is worth having. Some of the books I had were very old must have been from around 1900 all out of print. I can write up for you how I would undertake repairing a longcase clock, if that would help you. Watch and clock supplies tend to stock more of the popular books.
I forgot these mags have a fantastic amount of information.
http://www.clocksmagazine.com/
I can second Oldhippy's recommendation of the clocks magazine.
I have a current subscription and it has some real gold in it, also if you are into social media Clocks Magazine also has a facebook group, but I tried to avoid Facebook myself even though I have an account
I am working on another Grandfather Clock.
I think it should come out the front if I can loosen - and later remove - the screws holding it on the saddle to move it back about 1/4 inch so the wooden face-plate can slide down and out. Taking the saddle off won't give it enough room to slide out and it is very awkward to get at it. There are also 2 screws in 2 brackets holding the movement in place on the pendulum side that need to be removed but I'm thinking they can be loosened and left in place until I can see my way clear to take the movement out.
I see no other way to do this safely.
Do you have any advice regarding my idea(s)?
    • I just poked an inflation calculator, and $5 in 2020 would be about $6 in 2024. Doesn't fit very neatly into any status codes, which stop at 5XX, but that's honestly somewhat arbitrary outside of a clever pun for those that dabble in such things. Back during the pandemic, I would spend a good chunk of idle time in the evenings scanning through hundreds of listings a night, and I would only land 1-2 a week max. I would often go months without finding something suitable. A very small percentage of the watches in the price range are worth pulling the trigger on for my purposes. The number floating through the thread here may be somewhat deceptive.
    • Hi, guys I got there in the end after several attempts using a screwdriver and Rodico, I couldn't wait for the tool to arrive and was getting pretty confident handling the stud screw without it flying away. At first, I was using far too much Rodico, and then realized you only need the smallest amount inside the screw slot. Putting the cock back onto the movement also helped as it gave me more to hold onto while my shaky hand tried to align the screw wobbling away at the end of the screwdriver😁 Anyway, job done and I can move on. Thanks again for all the advice it's really appreciated for a beginner.
    • I'd be interested in a copy of this book if anyone has one they'd like to sell
    • You need to know at least the basics. Then the questions that You ask will begin to make sense. From what is seen on the video, the gear train and escapement look fine, but the balance doesn't rotate free. I can suppose that the thin gold colored shim that must stay under the balance cock is not in place.
    • Yes, there are a lot of shapes and all of them are used in different cases. The one in Waltham A11 is one of the most spreaded and is what I have shown in the beginning. Of course, the radius of the final curve will depend on the distance between the hole in the stone and the regulator pins on the cock
