Worlds Toughest Watch
Not sure if this has been debated before, but I have an old Seiko 7N36-6A40 from July 1996 that I bought cheap on fleabay 2 years ago. I have replaced the original rubber strap with a cheapo jubilee bracelet and it hasn't had a new battery yet. I use it as my everyday beater. Working as handyman it undergoes some pretty heavy abuse from painting to patio laying (today's job). It looked a bit grubby when I came home (sorry didn't do a before pic) so it got the usual clean up with a Cilit Bang (acid descaler) & a nail brush and this is what it looks like now..
I wouldn't abuse anything else in my collection like this, as quite frankly I wouldn't have any watches left apart from this one. Also it keeps time very well.
The three that spring to mind would be the ever-present G-Shocks, followed by the Suunto and Luminox brands. That assumes you are not diving to the Marianas Trench or taking on an Abrams tank. There's no shortage out there depending on budget and activities. So arguably, your Seiko is just as valid an entry if it can take abuse and keep on ticking and not cost an absolutely ridiculous amount of money...
Blacklab, I love your watch, simply, I love it! And its quartz movement is still available for about $US22! What else can you ask for! Precise, classy, durable, dependable and inexpensive! As I said before I love it!
Edited by bobm12
So far it set me back £41.00 for the watch including postage +  £28 for the bracelet, although I have found cheaper and better bracelets elsewhere.
Looks good, bullet proof and keeps good time. What else could you ask for?
How far do you travel to lay slabs? :-)
Just down the road to the local school.
Trying to imagine a coat of Seiko 7N36-6A40's... How would you ever keep them all synchronised? :P
The only time I change the time is when we go from GMT to BST and vice versa.
Thanks for your kind words. I have a few favourites, the old Sportsmatics & 7002's, but, not being a big fan of quartz, the more I wear it the more I appreciate this watch.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile, and not less mobile which is the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
    • Would it be correct to say that the stronger the mainspring, the thicker the oil should be? So for a fusee mainspring, should a thick grease be used?
