Electroplating At Home
Just noticed that my Accutron which is humming nicely still no longer looks as "golden as it used to".  The sides are really worn now and look more like nickel or SS whilst the back which is separate is still in really good condition, this after only about 8 months, though I did wear it continuously for about a month in LA and was hot and sweaty most of the time.
I have a couple of 10k Accurton cases and may swap it over. But I would not sell this case on to anyone.  I think that the person I bought it from must have used an immersion kit to give it a good but quite temporary shine.
I was wondering if anyone has dabbled in home plating.  I have a bit of old gold in my drawer so the raw material is there.  I believe the solution can be made up by dissolving gold in a Hydrochloric / Nitric acid mix and then you are looking at the transference via a current through the liquid.
Has anyone tried this ?
Cheers,
Vic
I think I will look into it.  It seems like an interesting and potentially usefull thing to be able to do, especially with old watch cases or even crowns.
I like Bobs info particularly the electroplating in miniature part.
I think that one of the highest costs is the soulution itself and if we can get that bit sorted out it might be quite feasible.  Worth a shot anyway.
Cheers,  Vic
Thanks Nigel, I will PM you about it.
Still tied up with the amp but always on the look out for something new and interesting.
Bob's suggestion is looking good as those small kits are available in the UK as well.  i think the most costly thing is the electrolytic fluid, if you can make that yourself I think the problem is largely cracked.  Lots of nasty chemicals involved but nothing I have not used before.  Muriatic Acid is, I believe just Hydrochloric acid which is available from most DIY places as it is used to wash down brickwork - further research needed :D
Cheers,
Vic
Edited by Vich
I used to have a big plating machine. There are two main kinds of plating, flash plating and hard plating and I used to do both with it.
Flash plating OK for anything that will not come into contact with your skin as it will wear off very fast. This is more useful for plating watch hands or movement plates etc. not so much for plating cases due to the lack of durability. The pen plating kit falls into this category.
Then there is hard plating. This is suited for watch cases as the plating is more thicker, typically 5 or 10 microns or more. The hard plating solutions are very prohibitively expensive for one-off jobs and you need an agitator as the piece needs to be in the solution for a long time and always on the move.
Some materials (like brass) will need a base coat (nickel (poisonous), Rhodium (expensive)) to start with as you cannot gold plate directly onto it.
I never managed to plate onto SS as I never had the knowledge or equipment to do so.
I am by no means an expert on plating, just a complete novice really. I keep a pen plating kit as it is useful for touching up bit and pieces on occasion. But I would say that plating onto a SS case could be very difficult and I would rather send the case in to a pro.
Be warned though - if you do get into plating (it's fun) then you will be looking all over the house for stuff to plate :D
I hope this helps.
Thanks for the info Mark.
I take it that you purchased your electrolyte rather than made it up yourself.  It seems like that is the main cost.
I just thought it may be interesting and a bit of fun and you have confirmed that.  I am still on the research phase but it seems like it is not too difficult but some of the chemicals are a tad nasty.  Loads of stuff on you tube about it - one is a guy from the uk using household cleaners to make up the electrolyte !? I have not seen all of his Vids yet but had to laugh as he explained that there was a US patent which he could not infringe then proceeded to tell what the constituent components were.
Cheers,
Vic
Never made my own salts - used to purchase from CooksonGold.com or HSWalsh
Now I just use a pen plater and I only use that a handful of times a year. There are sellers on eBay with kits at a reasonable price so that may be the best route because the kits from Cookson or walsh are quite pricy.
    • I'm guessing, but this commercial demag machine maybe produces random magnetic fields to re-randomise  the iron particles. So heres one for you, synthetic rubies are coloured predominantly with chromium oxide . But natural rubies and old synthetic watch rubies were also coloured with iron oxide in higher percentages than chromium oxide. Which gave them a degree of.................🤔
    • I've never had a hairspring distort on me by passing the movement or just the balance in a plastic pot over this demagnetiser. Have you seen how fast a cleaning machine spins to spin-off fluid and that does no harm to a hairspring. I was a little concerned when I first used it, thinking it might be too strong, but I was wrong. It is strong, but it does no damage. I pass the part over the demagnetiser and keep going for about an arms length, so about a metre, to properly demag the part.
    • I don't think you would be able to find spare parts. Your best bet would be to get a new movement from eBay. https://www.ebay.com/itm/256508500506?itmmeta=01HY3M863PSA61GK7B859QCWTE&hash=item3bb9191a1a:g:ubgAAOSwrJJgPP-s&itmprp=enc%3AAQAJAAAA4DxWhpiQiz2ZjKpm3PS%2FHPh4IafsSzMWEobc2q4qQWgPGMZ8kCR8y2PRsm7GE31FjeSDYSWcEyGlrpZEdQyyzOSgsgsaPjbP7dYmK8r49Nh%2BEtSqDDIZ8Tbp3vvX035fFXgcjc1GEH8l%2FOWJ9aTeWNGzeBgUwqyhJ3ZSXji50TQr6rd38Sqwaqsj2oc51UVKqqIKySKTfxVB7X09EXcJsmeYc5GCdVODNkb02q2RsxfSIzpgl9dFCmW1Ih%2BPg2j2NziSELg5AfaHl%2FPU2Zn9fNnoVN1Z1NUAREyh2BCubcWC|tkp%3ABk9SR_bhoPTwYw
    • Here's a thought. Try unscrewing the bezel and the crystal. If you have one of those sticky balls for undoing casebacks, I would give that a try.
    • Last week I noticed my Eco-drive's second hand was stopped at 12 o'clock. I left it in the sun for a few days and no change, so I figured it was time to replace the rechargeable battery. I've had this guy for at least 15 years. Replaced the battery and the seconds hand moved to about 5 o'clock and stopped there. I let it sit for a day in the sun, no change. I took the battery out and tested it, and it's at 1.4v. The old one was at 1.0v. I'd like to test if it's charging. I've been looking around for diagnostic info, but only been able to find the owner's manual. Anyone have a reference for it?
