Lubricants
By FabioBastardo · Posted
Hi i was wondering if you had looked at the photos of the watch. Do you know what it is. Obviously it’s very old. But as to the maker I have no clue thanks. 🙏 -
John, the plate (actually the barrel bridge) is not worn or at least this is not the problem. The big washer (which is also part of the crown wheel bearing) under the crown wheel screw in You movement is missing. If You put it as should be, then the movement will wind normally. But, as the crown wheel is now a little worn on the bottom side, You may have to put it upside down. A little ugly, but this is USSR movement -
I've ordered a cheap ST36. It's large and very well documented online, so even a dumbo like me can figure it out. After stripping and assembling it several times I'm tempted to reach out to my contact in Kiev and ask him to send me a bucket of old Soviet watches. I have a thing for the Soviet stuff.
