Hi guys, a friend has asked me to try and find out information regarding a gold pocket watch that he owns. It is a high quality 9kt gold watch without any markings whatsoever regarding the manufacturer. The hallmarks have been polished to the point that they are illegible although I can make out the the makers mark J.G on the case, but the pendant has another C.H . I am beginning to suspect that the watch has been built from a lot of odd parts at some time.
I trawled EBay and found a movement that is so close and is described as a "Leutonia" Swiss made.
Can anyone please help with information?
Below are two pictures of the watch and one of the movement on EBay.
Hi Geo,
Could it be possible that one of the watches had, along its life, had a balance cock change? The ebay one has a swan neck while the other one doesn't. Appart from that, I've seen out there (was searching but can't find it now), schematics of different balance cocks and who used them in their watches (and the years). It might be useful to identify the movement (starting point maybe?)
I'm still searching...somehow my latest researches on the web have not been too successful...I wonder if there is anything wrong with my ISP!
Edited by bobm12
Hi Bob, many thanks for the comments. I don't think that the balance and cock has been changed, it's possibly more to do with grade of the movement.
I see, I figured it was kind of matching in both cases but it was worth a try. I suppose the quest goes on. If I see anything I'll post again. Good luck!
System Glashütte!
After much research and also with the kind help of two members of NAWCC, I think I have got to the bottom of this mystery watch.
There has been a lot of talk lately about Chinese replica/forgery watches. Well it turns out that this is nothing new. The movement in this watch was made in Switzerland to mimic the German manufacturer Glashütte. http://translate.google.co.uk/translate?hl=en&sl=de&u=http://watch-wiki.org/index.php%3Ftitle%3DSystem_Glash%25C3%25BCtte&prev=search
I originally asked about the name Leutonia, and it should have been Tueutonia which of course refers to Germany! The suggested date for the watch would be between 1890 & 1910. Unfortunately because there is no makers mark or serial number on the movement, this can't be confirmed.
I am now totally convinced that the watch has been made up from parts that a watchmaker had lying around, as nothing nothing on the watch matches. The case and pendant tube are 9kt gold with different English goldsmiths marks, the dial does not bear any script and the the movement is a high quality Swiss copy of a Glashütte movement.
Good research Geo and good movement there. I'm glad you could trace it and find out the info you wanted. IMHO, regardless of the humble origins and higher goals of the movement, at this point it is a treasure found both in quality and in what it represents: a vintage "Glashutte" made in Switzerland, nothing to detract from the real thing...and another piece of history.
  • 1 year later...
On 2014. 10. 28. at 4:34 PM, Geo said:
System Glashütte!
Just bought a pocket watch like this. Nice info here, thank You Geo! Did You get more info on these movements since this post?
This particular one is the swan neck missing and the balance staff is broken. Another Dremel lathe project in view :)
That is the only information that I have Szbalogh.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
