Is there any way to tell if a back is screw on or snap on?  I know many snap on have a relief to get a knife in but I have heard some  don't.  Most screw on backs I  have seen have lugs to get something like  a jaxa tool  in but I understand there are some that are completely smooth like the old pocket watches.  I've got a few watches I'm unsure of so I thought I would ask.  Thanks!
If you don't have the usual tells, it can be tough. I just spent days fighting with a caseback on a pocket watch that I was sure had to be screw off, but I've come to the conclusion it wasn't meant to come off at all.
Information on the specific watches would help.
If you know how old they are, that can help inform things. Earlier than the 80's or so (I'm not an expert so don't use this as a hard date) screw backs were pretty rare. Especially on cheaper watches like Timex, those are almost always snap backs, or you have to pop the crystal and go in from the front.
If the back splits the crown with the front, it's almost certainly a snap back, as the movement is meant to be removed from the case without taking the stem out.
Thanks!  I feel better now as all of the watches I'm wondering about are from the 60s.  How in the world would you take a movement out from the top?  If you remove the crystal aren't you just presented with the dial with no way to loosen the screw to take out the stem?  I'm trying to imagine how one would do this.
It will depend on the watch. Usually watches put together this way have a two part stem. More detail: http://watchfix.info/Battery%20Replacement/One%20Piece%20Case/Battery%20Change%20on%20a%201%20piece%20case.php
Sent from my ONEPLUS A5000 using Tapatalk
Thanks, I bookmarked this page.  I messed up an old watch that had a two piece stem.  I tried to pull it out using advice I read here.  I had to use a ton of force, turns out the two pieces were rusted together.  I  bent up the  stem tube.  Are these  soldered in?  I have an assortment of tubes but no idea how to  remove one and install another.
Screw down backs have been around for quite some time and can be found on both high and low end makers.  Of course Rolex is a leader in this area as they developed the "oyster case".
Ok. I've never seen it on the lower end stuff of that era, except pocket watches.
Here are examples of lower end watches form the 1950s - 1960s.  All with screw down backs and typical 17 jewel movements inside.  note the extreme wear to some as they were not made of stainless steel.
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
