Landry from the USA new to horology
Landman
Hello fellow watch enthusiasts my name in Landry. I love pocket watches and I have a Waltham 1899 16s 7j pocket watch, the case has a nice engraving of a train on the back. This is my first pocket watch that does not have a battery my other one is a Mickey Mouse and the battery is dead again. I have always wanted to have a winding pocket watch. The watch that was given to me was not working and I did not know where to take it to have it serviced so I decided recently to work on it myself. I don't know much about watches but I am mechanically inclined. I am currently taking the watch Repair Course I am enjoying myself I just purchased some tools and I have some other pocket watches I got from Ebay. I wanted to work on some other watches before I started on mine.  I think I will be sticking to Waltham, Hamilton, Elgin, Illinois and the like. I did get one Swiss Galco stop watch in an Ebay purchase but I will work on that after I get used to working on other pocket watches as i'm not sure what I will run into with the Swiss stop watch. Look forward to learning some stuff here and chatting with you. Thanks Much
Hi Landry, Welcome here and you are doing OK. Regards, Mike.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
