Lovely find
transporter
Ahhhh Facebook market place, just picked this Hermle 791-681 up for £12, apparently it’s overwound, as we know you can’t do that, I put some power in the train and it ticked away for about 30 secs so I’m guessing a damn good service and clean and it will run like a good ‘un
Beautiful find, the dome is worth a bit if it's glass..Lovely clock..
image.thumb.jpg.a27757eb2101c108061f8d12b752f341.jpgiWell four hours solid work, ok I had a couple of cups of tea in between and I now have a lovely working and chiming some clock. It was a simple movement to work on (unlike the 3 train Westminster one that’s next) and again the old brasso lighter fluid and French chalk came into action for the great finish. I did find some of the wheels had a lacquer finish on them that obviously without an ammonia soak won’t come up shiney, but they do give a good contrast if you look close enough.
No significant that I could see, it's holding really good time, it was 15 minutes slow after the service but a few turns of the nut to raise the bob and all is well, I personally don't think it is very old, maybe only 10 years or so, definitely hasn't been serviced before anyway, as for the strike it's an hourly one only. And as for the french chalk it's great, I need to invest in a couple of new brushes though as mine is shedding lots of bristles every time I use it!
29 minutes ago, TimFitz said:
Very nice work & a very attractive clock :)
One question : What is French chalk, and what is it's purpose?
TimFitz
After cleaning and polishing brass. If you French chalk the brass parts with a soft clean brush it prevents tarnish of brass and can add that extra shine. Some clockmakers still use this old process today. It is also another way in which you do not need to bother to lacquer parts.
French chalk is magnesium silicate.
Cheers oldhippy beat me to it,  yep as old hippy says that what it does, its cheap aswell, I think I only paid a few quid for my block from cousins, you have to move the brush very fast but nice and light at the same time to get the best results, then peg out all your pivot holes.
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Thanks ww, its maybe not as much of a bodge trick that i thought it was.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  It would be nice if you told us a little about yourself.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  Can we help with what you are trying to  figure out?
    • In think you are effectively shortening the coil by shorting out damaged tracks. In my case as long as the continuity was good and the resistance not too greatly affected it should be ok .  One was on an era  movement,
