Hi from UK
Just about to start on Marks courses as, unless you wanna pay extortionate amounts to send a watch back to the manufacturer, as jewellery shops around here just don't know what to do! Then hence my desicion to take the course.
I did a quartz watch repair course in London a few years ago, from that, bought watches that needed attention (mainly Tissot) from an auctioneers in Birmingham jewellery quarter in UK, polished all the scratches out & repaired bringing back to New condition before selling on, or keeping for my own collection.
I had very many positive feedback for the polishing work I did but, my aim is to service automatic watches, as I believe it's now very sadly a dying art, hence the reason for joining Marks course, (and the fact I was quoted £300 to get a Tissot auto watch ticking again!!)
Great to be here!
Regards
Paul
The art is not dying at all, in fact luxury and haute horologery has never had a so large and sophisticated offer.
But when it comes to repair/service it simply that wrist watch has changed from a needed and regarded object to become a collector's item for some (few), and an almost disposable fashion accessory for others, while the majority of people doesn't care at all.
Watchmakers are not needed to be anywhere, and mostly work for official service center. And the few independent ones are doing extremely well.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
