The exit jewel came loose so I ended up pulling both jewels and removing the shellac. However, I'm having one heck of a time trying to reinsert the jewels. What is the preferred procedure for doing this?
It looks like in the photograph there is still shellac on the stones? Alcohol will dissolve the shellac they will have to be absolutely clean than they should slide in. They definitely will slide in because there supposed to be movable in other words there adjusted to an exacting position. It's why they use shellac under heat the stones can be moved.
Then the modern version of the tool showed above can be found at the link below. They do show up on eBay from time to time at several hundred dollars if you're lucky new price with the heater very very expensive.
http://shop.bergeon.ch/Catalogue/PDF/1092 C D.pdf
I joined today because one of my pallet jewels somehow got tilted skyward and was not engaging with the escapement wheel and a search brought me to this thread. I gave the wayward jewel a nudge and it seems to have rotated back into place, but I'm going to take a better look tomorrow when my USB microscope arrives. There's plenty of shellac still in the gap so maybe all I'll need to do is heat things up a bit. I'm not sure if its current position is the way it came from the factory or not, but I'm hoping a better view will clear that up.
That Bergeon tool looks nice but as a hobbyist I have a hard time justifying that kind of money. I did manage to get one of the jewels reset and am currently working on the other.
Have you read this yet? It's about the only information I could find about setting pallet jewels. http://raulhorology.com/2012/08/eta-6498-escapement-fitting-the-pallet-staff-and-jewels-setting-depth-of-lock-and-run-to-banking/
My hair-brained ill-informed plan is to simply heat things up holding the tip of a soldering iron close to the loose jewel while observing it with a USB microscope. When the shellac flows i will remove the heat and hope for the best.
Yes, I came across that link the other day. I used a piece of wood to make a "staking  block" similar to what's shown in the article. Still, trying to fit these small components is a challenge.
There's another option for something like this and that is dissolve the shellac ain alcohol and make a glue. Then you can just put a small amount on the fork let the alcohol evaporate and it's fine. This also works if you think the stones are loosing you don't want to play with heating them up you just glue things back. Then because this is still shellac if you have to move things around later on it works just fine. Versus some other inappropriate method of gluing the stones in.
3 minutes ago, audiomagnate said:
70% isopropyl alcohol
So the alcohol I have is labeled denatured alcohol. Says that it's for thinning shellac, cleans glass and metal and Clean burning fuel for Marine stoves. Nowhere on the canned this say what sort of alcohol it is. Googling the product code gives me both links below the second link actually looks like they can I have. Then I was wondering if they change the formula but I saw somebody already asked that somewhere else and apparently it's still what it's supposed to be which is denatured alcohol. Apparently that's an ethanol-based alcohol with a little methanol to make it Bad at least for drinking.
So you can try if your alcohol doesn't work and I'm concerned about the water content. Then hardware or woodworking store as shellac is used as a finish. And what does Google I was reminded you can get it pre-mixed with solvent zero idea as to whether it's suitable for our need and unfortunately even the tiniest of canned is a lot. Plus you can buy the shellac as flakes for wood furnishing and that does work for watch repair it just comes in a really big quantity
https://www.amazon.com/Klean-Strip-GSL26-Denatured-Alcohol-1-Gallon/dp/B001EMB2A0
https://www.amazon.com/Klean-Strip-QSL26-Denatured-Alcohol-1-Quart/dp/B002MBX2QE/ref=pd_sim_60_3?_encoding=UTF8&pd_rd_i=B002MBX2QE&pd_rd_r=0a2270f3-7cc9-11e8-ae7d-27beeed8d987&pd_rd_w=6e08C&pd_rd_wg=xEPlz&pf_rd_i=desktop-dp-sims&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=7967298517161621930&pf_rd_r=PBR09Q93MVQBRCKBCARV&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&psc=1&refRID=PBR09Q93MVQBRCKBCARV
Other options for holding your pallet fork images attached. Commercial tool holds the fork down. Then a lot of times I'll just use the brass plate and has a variety of holes. It was just simple and easy to make and the reason for all the holes was it can also be used for bluing screws.
Upon closer inspection, it looks like the gap is not supposed to be there. The jewel in question is the one on the right in the first photo and shown in closeup in the second photo. The third photo is of the properly seated (and lubricated) jewel.
When I have fitted the stones I have made sure both are exactly the same height. Using the the tool I showed in my original reply post makes this relatively simple to achieve.
    • Many thanks for your answers: 1. I will clean both of them without risk 🙂 2. Both of the rotate inside their setting but they don't seem to come out. I will clean the cock (and the hole jewels) and I will see if they want to go out. I don't intend to force the setting pushing it out by any means. I only hope I don't need the dismantle the whole cock into all its components...! 3. I won't touch it. Only clean. I don't want to take risk... Thanks again!
    • By worn pivot, Do you mean short ?   A pivot is not short if balance spins freely on it. Dial up & dial down tests are good test for investigation, visual test alone doesn't suffice. A thorough test is free oscilation, which is best done when balance cock is adjusted with acceptable end shake. Balance settings on both side should be dismantled as they must be cleaned, pegged and inspected.  Regs
    • 1. I think the pivots look pretty good and I wouldn't worry about wear. 2. Yes, I think the hole jewels should come out for cleaning, complete with their spring setting. I don't have experience with Rolex but I've seen this spring type setting in another movement. They may be stuck in with old dried oil. 3. Yes, I think the overcoil is out of shape.
    • Yes, I'm looking at this option. I have a good friend from childhood who happens to be a goldsmith, and he would certainly be able to tackle the second hole to my specifications. I usually avoid this path because, since he deals with gold pieces, every time he stops to help me with "frugal" parts, he is objectively losing money. I agree with you. Even though I couldn't justify paying this much for the set (they only sell the whole set or the sole case tube), I understand the price tag. The trouble with this particular stem set is that the most common use case for it is the Technos Skydiver, a watch whose price certainly justifies 220 USD for a brand-new stem set.   I have messaged them only on the surface, without specifying my needs. They already stated that they don't sell the single female part, only the full set. What I still don't get is the need for a second hole. Is it supposed to be some sort of regulation, meaning that I can fit the head of the male part in any of the two holes to adjust the pressure of the spring? Does this mean that a single-hole female part has a chance to work with my setup? I'll later test this hypothesis while continuing the assembly of the movement. Some photos are attached. Can you judge this bracelet? It was dirt cheap (4 USD), genuine leather, wife's choice. I have just realized my dial is upside down. lol
    • Hello from chilly Brazil! I just bought a couple of watches and this watch came with them. While perhaps not worth much I'd like to try to find out something about it. Googling comes up with with the name Gerald Genta, and I see from internet searches he's made some nice designs (perhaps an understatement)! Also some cartoon designs but I can't find anything like this anywhere, so most likely not his!  Googling Royama I see that some famous people liked his watches and also the Royama watches. Two questions; 1. Can anybody tell me anything about this watch and its background? 2. How to get the base off to let down the main spring which is fully wound. I gently tried prying it but nothing, I see there is a button but have no idea if it is functional for removing the back or anything else. Screwed back maybe? I really don't want to break the back or the watch with too much pressure and haven't looked up the properties of Grilamid!   Probably not much of a watch but it peaked my curiosity and I hope somebody might be able to help? The auctioneer sold it as a psychedelic acrylic 1960/70 Royama watch overwound! All the best...Jules
