Got another aircraft clock coming
Tmuir
As Ebay will get 10% more expensive for me after the 1st of July with GST being added to all our purchases in Australia I have been doing a bit of a shopping spree.
A book I have been wanting for some time I finally caved on.
British Military Timepieces by Knirim, Konrad as I already have Miltary Timepieces by Whitney which covers USA made military timepieces and I have been wanting one covering British made ones and I then also purchased Longines-Wittnauer A11 clock.
The price was fair, not cheap, but fair, it helped that ebay gave me a $10 US voucher which I used to lower what I paid.
I fully expect it doesn't run but I'm hoping it just needs a clean and service, but we will see when it arrives.
https://www.ebay.com.au/itm/AIRCRAFT-CLOCK-AC-41-LONGINES-WITTNAUER-WATCH-CO-1-7-8-INCH-DIAL-8-DAY-WOOD-CASE/173378573957?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
When it arrives I will give an update on its condition.
Ebay US hasn't ever been a good place for foreign buyers anyway. Too many sellers insisting on "US only", if not "lower 48s". Or pay the craziness of their "Global Shipping" program. Much better to be on the various forums, gain a bit of reputation, and deal there only. With few exceptions (got great micro-O-rings from Aussie sellers) I'd rather buy on Craigslists or Gumtree.
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
