Hello :) I have been wanting to start using my Ferrari watch again (yes, it's a fake but I like it) but I can't remove the back to replace the battery. I bought a cheap toolkit to help with this but the notches on the back of the watch are so shallow the tool keeps slipping before I can turn it. Is it definitely a screw-on/off back? I've also tried levering it off in case it's a snap-back case but no luck there either - it doesn't budge and the tool slips and scratches the back. Help please! :)
Those notches on the caseback don't look functional to me. Have you tried placing a razor between it and the watch case and gently wedging it until you can create a space large enough for a caseback opener? You'll need an opener that has been sharpened with a stone to have a fine edge.
J
My toolkit came with a little knife thing which I can't get under the caseback. It's not sharp enough to break the skin but it's pretty thin.
It is difficult to be sure by your pic but it is highly likely it is a snap back. If you look at the edges with a good loupe if it is a snap back there might be a lip for the leverage. The watch looks very dirty and as a consequence the back will be very tight. If it is a screw back then a pro style opener will be the way to open.
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
