Have this old Hampden gladiator pocket watch from my grandfather . It was working  when i was a child. But  when i moved someone dropped it to the floor. Not me that time :)  Breaking something. Probably the balance staff. I have been wanting to repair it but don't know if it's possible. What do you think.  Looks like some parts are missing also.  Is it even possible?
DSC09884.thumb.JPG.5a959043bd97280bb0d382920fb012d6.JPGDSC09883.thumb.JPG.e3dd6c43907f5a0e5be448e20bcc3b0e.JPGDSC09882.thumb.JPG.0ae1f919c255ae37ffe1a5ee80d4c75f.JPG
Found this on youtube.
Edited by rogart63
I think you are going to need another movement with the balance complete, or someone who has many parts for this cal. From what I can see you are missing a load of parts.
I love Hampden 18s pocket watches & have four that I have restored & probably that many as parts movements. I don't want to know how much time & money I have invested in this beautiful coin silver favorite of mine
If it is very important to you for sentimental reasons I would say go for it.
Time i have . Is it even possible to do? It would be very cool to get it running again. What shall i look for. I have search for Hampden Gladiator . But there is a lot of different movements out there. Not sure where to start looking. I can service watches but have worked on pocket watches.
Balance is toast . So is the pallet fork. Some  screws are missing. And the regulator arm is missing to.
I think you need to start at the Pocket watch data base to get all the information about your watch. Go there and type your watch serial number into it . The site will tell you model, jewel count etc.From there you can search Ebay for the correct model , jewel count & with all the information you have.
I'm sorry if I am repeating things you know but I am just assuming, correct me if I'm wrong.
Here is a link to the data base. https://pocketwatchdatabase.com/
Now you can begin :)
44 minutes ago, TimFitz said:
When doing this type of thing the " Hunt" is the fun part i PM'd you with another place to look
I have box after box full of fun :pulling-hair-out:
    • My name is George, and I am a passionate watch enthusiast, seller, and content creator in the watch community. I am very interested in expanding my skills in watchmaking,watch Design and repair.   I would love to inquire if you offer any mentorship programs, internships, or volunteer opportunities where I could learn directly from experienced professionals. I am eager to contribute, learn, and deepen my knowledge of the craft. Best regards, George M @watchmegobroke
    • If a runner, I usually let the movement run in naphta for a minute, some movements need a bit of encouragement to run in liquids, so a quick dip of the movement in naphta then remove and encourage the oscilator with puffer, repeat several soaks.  Or if you don't want to soak or dip the movement in cleaning solution ,   keep putting naphta on jewel holes as the movement runs on bench. A pre-clean of some sort  helps.  Avoid lifting out the fork with tweezers or any tool.  Try blowing fork pivot out  with strong puff of air from jewels holes back side. Good luck .
    • 60! Wow, that's a lot. Can't say I understand the problem because disassembly is usually quite uneventful, except for springs launching into space. Most people break pivots during assembly. I use a homemade brass pry tool to loosen parts. It's just a short length of hard brass wire sharpened to a chisel point. Don't pry at just one point and crowbar it out. Pry at the notch and when a crack opens up, slip the pry tool in and loosen it at a few more points until the bridge is free.
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
