I was given two old watches to fix yesterday. An old Everite and a Longines. They have been in a drawer for many  years. I stripped the Everite,  and well serviced it but it does not run well. The Beat error is 600 micro seconds (0.6 mS) and the balance amplitude varies between 140 and 190 deg. The HS is fine. The lever flicks to the banking and the Draw seems to be OK. It is keeping time to about +2 mins/day face up and a smaller amount face down,  The best I can achieve.  It does not look very good on the timegrapher. Is this a case of general Bal/Esc wear. The end stones look OK. Under the microscope I can see pallet jewel  witness on the teeth of the ESC wheel.  It was purchased in the thirties and used for many years. I have boxed it up. Perhaps someone will comment.
Did you check the impulse jewel to see if it was chipped or loose? What type of oil did you use on the ecsapement. You know pallet pivots should not be oiled as it can and will cause drag.
Thank you for your help Oldhippy. Yes, the impulse jewel is firm. I used a tiny amount of 9010 oil on the escapement but not on the impulse jewel. I did however use a touch on the pallet pivots !!!! I will remove this today.  I do not feel safe without the tiniest touch of oil on most bearing services, a habit that I must get out of in some areas.  I can see where you are coming from with regard to the pallet pivots not being oiled, oil could be the cause of a weaker impulse to the balance,  I will let you know how I get on in due course. Many thanks for your constructive and expert help to an old Jobber !!. Best regards, Mike.
Hi oldhippy, I have just finished the Everite watch and your comments about oiling the pallet pivots were Spot On!. I cleaned them with Acetone, dried and then re-assembled the balance. The balance now has a steady 220 deg. Amplitude.  I have timed it to +30 Secs per day. It is much better now. Thank you so much for your correct diagnosis and perhaps 9010 is a little stickier than I thought. I have learnt something from your years of experience and am most grateful to you. Thinking about it there would no real need to oil the pallet bearings as the rotational moment is so small,  I realise this now that  you pointed it out.  Thanking you again,  Best regards, the old Jobber  Mike.
spot on !.
Thinking about it there would no real need to oil the pallet bearings as the rotational moment is so small. That is correct. Glad to be of  help.
Thank you again. I could hardly believe the oil on the pallet bearings could have that much effect. I will not oil them again. Mike.
PS. I always maintained  that in any kind of engineering,  if there is a problem that is elusive the smart guy is the one that diagnoses it. The  fix being the easy part as a rule. thanks, Mike.
  • 1 year later...
Yes it is hard to believe the retarding effect of oil on pallet pivots. Even worse is: if the watch( some movements, especially pin pallet)  isn,t worn for couple of months, oil can freeze the pivots from functioning.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
