Sticky hairspring; how to demag and what does the hs alloy do?
Its hard to see, but you may need to add timing washers and not just move the screws. If they are free running when turned slightly then you will need washers. If they are still tight-ish, go for half a turn each to start. Remember, just the 2 nearest the arms.
Best to turn with a pin vice to avoid damage, and with the balance removed.
Edited by StuartBaker104
On 6/4/2018 at 1:25 PM, rogart63 said:
Looks okay to me. But when i have some trouble with sticky hairspring. I sometimes clean it i acetone . Just a quick rinse will do. Or use a brush and then naptha . As the naptha doesn't remove the old oil properly.
Yes, I almost always use Acetone on the balance and finish off with Naphtha in the U/S.
Before jumping in with poising the balance, make absolutely sure that the hairspring is not sticking anywhere or touching anything (especially in the fast position. Then inspect the portion of the hairspring where it sits between the index pins. It should be centred and “breathe” between the two. The gap should be approximately 1.5x the hairspring thickness, ie. it should just fit.
Once that’s done, you can look at poise and also slowing the overall rate. As Stuart mentions, you can add weight evenly at the arms to drop the rate.
If it were my watch, I’d look for a new balance complete, unless you fancy a difficult challenge.
Hi rodabod and thanks for the feedback!
After the repinning operation, demag, cleaning etc. I think it’s running correctly (but too fast due to the shortened hs).
I adapted the beatfrequency manually on my timegrapher to get horizontal lines and it looks pretty ok.
Your comment about the hs passing the index pins is interesting and a thing I would like to understand better.
The more ”modern” movements I have worked on often have the hs end re-shaped in a circular fashion to allow the hs to stay centered over the entire adjustment range. The raulhorology link in this thread is a good example.
I very rarely see this implemented on the older movements from the 30’s - 50’s where the hs simply ends along the spiral path which makes it hard if not impossible to maintain that centered position and the hs movement between the index pins over the balance rotation becomes very much of a compromise.
I would appreciate any thoughts over this from the experienced.
I would like to find a complete balance replacement but think this will be a hard find. The shock protection is of unusual kind and I doubt there are many parts out there to find. And besides, I paid less than 10 euro fot the thing to start with so heavy investments are hard to motivate... :-)
I’m not quite sure what you mean. The hairspring between the regulating pins should be free wherever the regulator is between the h/spring it should be able to bounce between the two pins. It should never just rest against the regulator.
Hi Oldhippy,
I was just referring to the fact that I seldom see the more advanced hs endings as in the attached photo on the older watches I tend to spend time on.
One purpose of this elaborate shape must be that it allows for a constant hs radius over the regulator slow-fast span.
Without this shape (as in the older movements) the hs radius will vary slightly over the regulator slow-fast span and make the whole thing much more of a compromize when it comes to the hs position in between the pins.0d33a6e6c6dd197150f27f437c14575e.jpg
Hi all,
To wrap this up....
I attempted to loosen the timing screws as proposed and was able to make them turn but can’t see any radial movement, so I guess there’s no real thread on them, just push in.
To have any effect I would have to remove entirely and shim under.
Won’t go there right now (or ever...) and just slowed down as much as possible with the regulator (way outside the scale but no apparent mistreatment of the hs).
Still runs a bit fast but runs and I’m happy with that.
I have attached a photo of the assembled watch for those interested.
Thanks for all help through this process!
/bsoderling
    • Personally I would salvage the missing screws from some donor movement.  I also bought a random selection of screws "Assortment of Stainless Steel Watch Screws" for next to nothing.  As for using an Alum solution - I had great success with that removing a rusted stem from a stainless steel crown.  The best piece of advice I read on doing that was to keep the solution warm so that the reaction didn't take weeks!  I did it in a couple of hours with the solution in jam jar and the jam jar in a saucepan full of water which I left on an induction hob maintaining about 60C in the Alum solution.
    • I decided that it was time to tackle the piece that I'd set aside as my first project. The subject in question is a Gruen Veri-Thin pocket watch.  It winds and "runs".  On the time grapher, it has reasonable amplitude (240 or so depending on the position), but was loosing close to a minute a day.  The stem also has the annoying tendency to just come out when pulled, which makes it super hard to set the thing.  As with many things this one started sideways and just got more so.  I was able to overcome the mangled "tab" on the back case cover (a well placed, very sharp knife enabled me to get in when I couldn't get a purchase on the mangled tab with a case knife.)   I was then sort of shocked to find that one side of the dial was held down with some sort off tape or adhesive material as someone had broken the dial foot screw on that side and left the broken screw in the mail plate. The loose stem does in fact seem to have been a poorly tightened setting lever screw, but I'm afraid there may still be gremlins in the keyless works.  While I was able to get the stem to stay in by putting everything in the right place and tightening the setting lever screw (before I took it all apart for cleaning and inspection), it just didn't seem to all sit right. The final gremlin showed up when I was taking off the lower cap stones for the balance and escape wheel (yes the Gruen 380 seems to have a cape jewel on the escape wheel).  The balance stone came off fine (but that in fact is the smallest screw I've ever seen.  When I turned the movement around to get the one off the escape wheel setting, I found that the screw head had been mostly sheared off.  After some reading and looking at what I had, I decided to try and tease what was left of the screw out of the hole by nudging what was left with the corner of my smallest screwdriver.  After 20 minutes or so, I was able to get the remains of that screw out. The picture I'm including of the disassembled movement was taken before I got the second cap stone off, so in the picture, it's still attached to the main plate (for those looking carefully, you'll only see the one cap setting in the pic.) Now I'm left with: A broken dial screw inside the main plate that needs to come out A broken cap stone retention screw that I have in my parts tray, but that is strictly useless and needs to be replaced. The need to get another dial foot screw I'm contemplating solving the first problem by soaking the main plate in an alum solution.  I think the main plate is brass and shouldn't be affected, but I have not been able to confirm.  This seems like the easiest option as I can't really access both sides of the screw to use the pricey Bergeon tool (which I don't fancy buying unless I have to.) I have located a couple of donor movements and have questions out about whether or not the include the dial foot screw and prompting for pictures of the dial side so  evaluate the cap stone settings.  I've also found that a supplier in this country does have the cap stone settings, but isn't overly clear about whether the screws are included. Are these the types of things that one can scavenge out of assortments or is it best to just grab one of the donors assuming that they look like they have what I need?
    • I visited this place last year just before they closed their counter service - amazing shop (filled from floor to ceiling!) and the guy that was working there was really knowledgeable and helpful!. Their website isn't as good as Cousins but I understand that if you fill out the contact form they have stuff that isn't on the site. https://gleave.london/mineral-flat-bottom-domed/
    • As always in this game the answer is “it depends “ because the first one worked out ok doesn’t mean all will. A case could be made in a way that it would not really matter much, sounds like your first example. However a case could also be made so that only a tension armoured crystal could be used. Generally you replace like for like to maintain the integrity of the watch.   Tom
