How would one polish/repair this ?
As the title says how would you remove this "stain" or mark on the metal ?
Does this look like chrome/nickel ? Could this be plated or is it solid metal ? This is a Longines pocket watch from the 1910s in case anyone wonders.
I'm guessing someone may have tried some acid or stone testing on it to see if it's silver ?
I have some of that diamond paste that's supposedly used for mirror finishing but not sure how to proceed here.
IMG_7281.jpgupload gambar
Edited by Chopin
Are there any markings on the inside of the case back if its European and silver from that era it will have some form of halllmark on it anyone testing for silver content and leaving a mark like that is an idiot imho.
I would guess at the case being one of the lower grade silvers 800 standard but this would be marked as such.
It's not silver. I gave it a go with one of the polishing pastes that I had and it worked perfectly. Now pondering whether to "shine" the entire case...
I'm guessing it's stainless steel ?
Its probably nickel plated. Stainless didnt become popular in watch manufacture until the  early 1930's it was too difficult to work using method in use at the time and far too expensive a material when first introduced in 1913.
I think the resistance to wear will have more to do with the hardness of nickle as opposed to the hardness of gold which is much softer, pocket watches on the whole fair better than wristwatches having spent most there life in a waist coat pocket.
But whatever the materials used if in regular use it will eventually wear but I have many plated pocket watches over 100 years old that are still in very good shape, but I avoid gold plated  or chrome plated wristwatches of any era because they dont hold up well to constant use once the edges of the plating on the case starts to go its all down hill from there.
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
    • A lot of it has to do with a generations attitude.  Have we reached a generation of folk yet that have no sentimental values ie. Just an object to sell . I expect my kids will sell my collection , maybe keep one valued piece. Not being in the game very long, i have no idea when the sale of old watches boomed or if it has even reached its peak yet. If we go back 20 years what were ebay sales like then, expense wise and volume ?
