Fuddy Duddy Watchmaker
My wife threatened to buy me this http://www.ebay.co.uk/itm/Kay-Kyser-The-Fuddy-Duddy-Watchmaker-Lets-Get-Lost-78-Columbia-36673-TESTED-/121449332883?pt=Music_on_Vinyl&hash=item1c46f1c093 last night. Having listened to the words carefully, I don't know whether to take it as a compliment or not!
Listen here:- http://m.youtube.com/watch?v=8118Nte2k1c :-)
well at least it swings!
    • Hi I got a Jaeger LeCoultre K911 movement, where one of the stems was broken. Part no. Should be 401.  Im based in Europe and tried Cousins but its discontinued there and cant find it on Google. Is there a way out to join the ends? Or an alternative movement to source parts from?
