Hi everyone,
Just started the service of my Seiko Presmatic 5106-9000 and when removed the movement realized that the dial was lose and both dial screws are broken and inside the main plate (see photo).
First time in my amateur experience dealing with this, so any suggestion on how to remove the broken screws from the main plate is very welcome.
Many Thanks!
As the dial feet sits outside of the movement. Maybe the the part screw is loose enough to be removed with a small screwdriver?  Or maybe it will come out when you clean it. Do you have a ultrasonic cleaner. If so test to clean it first. Those screws has a tendency to rattle out if not tighten up before Ultrasonic.
