How To Adjust Bergson 30115-2 Micrometer
jdrichard
Did it come with any tools? Normally you would have a c-spanner and this would be used to move the spindle.
Not familiar with this model but I suspect the black collar where the sliding anvil comes out will loosen the sleeve, allowing you to 'zero' the tool correctly.
These usually do not need adjusting and such a big error as yours could be caused by dropping the instrument. Check that the measuring surface (called anvils) meet 'flat' otherwise it will never measure correctly. This can be straightened but needs a machinist to do it well.
Anilv
Anilv
Did not come with any tools and there is a small screw on the side as well.6fd062700138b04de3c041d0603165a7.jpg
If you can remove the set screw and move the index barrel round that may solve.
These are pretty simple tools and are meant to come apart for cleaning. To work well they need to be greased and function smoothly. A binding tool may give the impression that the tool is up close to the item being measured when its actually the tool binding.
Good luck!
Anilv.
Good luck!
Anilv.
Don't use grease. Maybe some 9010 would work best. To thick grease or oil and it won't work.
Edited by rogart63
Good luck!
Anilv.
Is the small screw next to the Zero the Set Screw?
Sent from my GT-N5110 using Tapatalk
Good luck!
Anilv.
Loosen that a little and you can turn it to zero the  scale. Make sure the parts are clean and the measuring pins are clean . Or what they are called. No need to loosen anything where the friction pin is i think.
I'll try that, thanks
    • My $12 blue one seems to work well enough for movements out of case. However for  tools with greater mass, such as my small and large anvils which are highly magnetized the blue unit is useless.   For whatever reason, my high current K&D donut unit just doesn’t seem to work, regardless of my attempts to use it as instructed in this thread (magnetizes stuff fine so I know it is energized).
    • PUW1563 is the day/date version of the 1561 (date only). I have just measured a 1561 using the old "blob of paint on the rim" technique to determine the actual amplitude by observation, and then putting it on my TG and adjusting the TG lift angle until the displayed amplitude matches the observed amplitude. I get 48°. Not a million miles away but it will have overstated the amplitude by about 20° with the TG set to 52° (I tried that as well for completeness). So with a more appropriate lift angle set on your TG you would have got an amplitude reading of about 240°.
    • Ok maybe that's the case - I was following this recommendation from: https://watchrepairtutorials.com/ultrasonic-watch-cleaner-how-to-get-great-results/ Here it is described to do the wash at 137 deg-F, which is 58 deg-C and he tested Elma Red with the described cleaning routine (10min wash, 5min rinse distilled water, 2min rinse 99% IPA).
    • My dad has a Citizen Pro master Wingman with a C720 movement in it. He took it to Timpsons for a battery replacement and the guy in the shop said he can't guarantee it will still be waterproof. Anyway it turns out it's not waterproof and now it's full of water. Would anyone know where I could find a technical sheet for this movement? I've tried looking online a bit today but can't find anything!   Thanks in advance
    • You would at least need to poise through those positions before regulating.
