Hi I'm New To Wrt
mlfloyd1
Hi everyone.  I too, am a watch enthusiast.
As you can see I'm starting to build up a tool inventory.  I now see how things start to build up.
I'm glad I found a hobby that I enjoy.  I find it both relaxing and rewarding as I become more familiar with disassembling and rebuilding a watch.  Already I replaced a mainspring and a case crown tube.
The fear is beginning to subside.
Well anyway, I'm glad to be on board and look very much forward to fellowshipping with everyone here.
Here's my temporary work area (my computer desk); I'm working on getting a table top watch repair desk.
Copy that.  I really have to get a separate desk with drawers and especially side-rails.
I've already had to order a click spring that went AWOL after I tried to insert it.  The dark brown woodgrain surface doesn't help either when trying to find parts that pop out of the movement.
Edited by mlfloyd1
Welcome to the forum from Scotland, you're obviously well on your way with this great profession/hobby. I'm sure you'll enjoy being a member of this forum. The boss, Mark, has done a great job setting this place up and his instructional videos are second to none!
Edited by Geo
Welcome to the forum. I am new myself and I see you are very organized... someone gave the suggestion to get a mat and that is one I didn't think I needed until things starting falling and bouncing off my computer desk. I work and go to school so I usually do my watch work late at night. You don't want to be that person  searching all over the floor at midnight for that dial screw believe me!
JC
I find Geo's solution to watch work space is both practical and elegant: http://www.watchrepairtalk.com/topic/841-workbench-height-solution/
maybe you guys might want to try something similar. The advantage is you don't loose desk space due to the portability of it and the height is always right. The raised edges in combination with the mat's texture and color will prevent most parts to get lost. Also a good work place illumination is paramount.
Edited by bobm12
Hi,
   Welcome. I also use a small desk similar to Geo's with the exception that I had mine built with several drawers which I find are completely full of tools. Maybe this weekend I'll post a picture of it. A guy at work built it and on his own installed a felt mat. It's too dark but that's fixed by placing a lighter colored one on top. Anyway welcome to the forum.
Charles K
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
