Citizen Eco-Drive CTZ-A8083 Glass
I managed to smash the glass in my Citizen Eco-Drive CTZ-8083 with a hammer whilst working.
Glass shattered and all fell out. The watch itself is still working fine amazingly.
I would like to have a go at replacing the glass myself but how do I find out the exact specifications of the replacement glass I need?
Thanks
Richard
For this watch you pretty much need a generic round flat mineral glass. You're going to need a pair of calipers to measure the diameter and thickness of the glass.
A bit complicated to do without the glass itself but still doable. You should at least be able to get the thickness if you have any pieces left from it. As for the diameter you just measure the slot in which the glass stays.
You can order them from CousinsUK as they are cheap and you could get a few sizes to be sure that you're getting it right the first time.
The calipers need to be double digits for best accuracy.
Oh, you also need a glass press. Cheapest chinese ones go for about 10-15$ on ebay. Some glasses also have a plastic gasket around them, some don't.
I was rather hoping that it was possible to obtain the glass specification from the model itself as there is no glass remaining to measure.
You will only find the OEM glass for specific models usually the top of the line ones or the really popular models.
It's not difficult to make the necessary measurements on the case if you have some calipers.
Better buy some calipers then.
I assume that will help me with the diameter but what about the thickness?
It's a bit difficult to measure the hypothetical height of the glass because you can't fit the calipers "inside" the case but you're going to have to approximate that one until you find the more or less right thickness.
Most glasses have a thickness of 1mm, 1,5mm, 2mm, 2,5mm, etc. You get the idea. So just try and see what is the closest figure.
I recently had to replace the glass of a Seiko. The original one had a thickness of about 3,2mm but I went with 3mm and it fit perfectly. Even looks better. So my advice would be to go with the slightly smaller height, in case the glass had a less common thickness.
Seiko, and I guess many other makers, often don't use "standard" thickness. For example, caseback crystals can be 1.6mm, not 1.5.
But as mentioned that is not much of a problem, the nearest common thickness will do just fine.
I know that they don't always use common thicknesses but since he said that he can't find an OEM I suggested a generic one.
As I said I just fitted a generic one on a Seiko and it looks pretty much spot on. You can't tell the difference at all because it's just 0,2mm or so...
I think I have the diameter sorted but struggling with the glass height.
I can measure the recess but do I measure to the gasket? or to the base of the metal where the gasket sits? and do I allow for some glass to sit proud of the frame? say .2mm?
cheers
R
    • I'm currently 3D printing a new basket and trays for my Pearl machine - I printed one last week in PETG material and it worked well at first. I had taken a calibration cube and soaked it in old cleaning fluid for 8 weeks and then measured it, and there was no discernable swelling or shrinkage and the cube seemed mechanically intact. All went well after the cleaning cycles and then onto the drying cycle..... that's when things went awry. The heat was more than I was expecting and the basket and individual trays warped and deformed, I later found out that PETG is rated to 65°C working temperature (PLA = 54°C) I am now trying to print from nylon (working temperature = +/- 100°C, depending on the specific blend) - but it is extremely difficult to print with, my third attempt is chugging away now while I am at work - hopefully I don't go home to a ball of wool like last time!  Assuming the heating compartment can't go higher than 100°C.... but not second guessing myself...anyone have any ideas or measured it? I also have a question on the trays, maybe I'm not seeing the obvious, but how do you use the ones identified with the arrow? they are called  Basket_for_large_mainplate_and_mainspring.stl Basket_for_small_mainplate_and_mainspring.stl I can see the place for the mainplate, but how are you supposed to place the mainspring, you can't uncoil the mainspring to fit around the outer circumference of the tray or else you would damage the inner tight coils. Is the idea that you supposed to lay it on top of the mainplate?
    • It is possible to true the pearl basket to run better takes a good hour of filing though.
    • Yes, the general pat is this. On my diagram the points where the springs rises and levels are marked with red circles. This is only to show on all pictures (the ones that doesn't show this points as they are seen only from aside, not from above) where this points are. On You pictures, the pont where the spring rises is not marked. The point where it levels is marked with A. The point B is where the change in radius should start, but there is sharp bend there which should not be that sharp.
    • I agree, very minimalist dial,  but then the diamond. The 1973 R has a black dial and gold case and is similar in layout. But on the MyBulova site there really is nothing else like it...
    • This is such an odd Bulova. Off of the top of my head the only other mechanical Bulova that I can think of that has the 'Bulova' logo as an hour marker is the Golden Clipper 'J' (there must be others), one of my favorite dials. And then it has a solitary diamond, which is not unusual with Bulova, but paired with the 'Bulova' hour marker, that only leaves two quarter hour markers, and I can't think of another Bulova that has only two hour markers like that. You do you Bulova, no conformity here!
