Buler
Cheers Bob,
I will post a picture of the innards when I get it apart.
Unfortunately I have to prep the front door and surround for staining tomorrow.  Its supposed to be good weather if you can believe the forecast and it needs doing before autumn sets in. Wire wool is the order for the day ho hum.
Hi Vic, I wish you well with both projects, I know what one I'd rather be doing. I'm away to grout rough surface tiles today, and I'm definitely not in the mood to do it!
It rained everything is masked off outside and only one coat on - is it me or are the dates on the postings showing November ?
Yup - the forum's showing November - that's why it rained when you wanted to do your outside painting. Mark's fixed the weather as well! :D
Well I can't do owt outside so I took the back off.
The Movement is marked - Brevets, Swiss Made, 17 Jewels Unadjusted Buler Watch Ltd., BFG 158 31/7.
The spring is hanging loose at one end.
The time is displayed on three disks and the seconds disk was rolling around in the case but the other two are firmly fixed and can be changed with the winder.  There are two small apertures on the minutes disk that presumably are used in some way to remove same but one thing is for sure normal hands lifters are not going to fit but a home made tool is likely.  It looks like the inner side of the crystal has been slightly scratched so I am going to have to find some appropriate matching black paint that is not going to lift any of the good stuff off.  So spring problem and crystal to attend to and disc removal so I can clean it after dismantling.  The good news is the steel case which is dirty but in quite good nick considering.  Here are the pics.
Vic
what are the missing parts?
I may have a suitable donor in my parts/projects box but if the missing parts are specific to the jump hour function then I know can't help as all my spares are for conventional hands.
Downloaded the PDF for parts from Cousins and it seems that there are some bits missing :thumbsd:
That's a bit of swine, let's hope Marc can help you with what you require. This is what I like about this forum, the way folk are willing to help one another.
Hello Marc,
I am still investigating but the spring is not attached at the outer end and if you have a quick look at the photo there is nothing to attach it to or that it has been attached to.  I am not familiar with this movement at all but on others I have worked on there was a + and - on the cock and an adjuster and this one seems totally without.  It is quite interesting i found one article here - http://watchguy.co.uk/service-repair-buler-baumgartner-bfg-158/ . It may be a pin pallet movement - new to me.
I see the problem, the whole regulator assembly is missing and I would guess that the hairspring is probably not too healthy either.
I have done some rummaging and your in luck. I have a complete and running (albeit in need of a service) BFG158 in a Buler which should provide any of the going train parts that you need. Dial side will be different though as it is conventional 3 hands and a date but with any luck you don't have anything missing from that side.
It is definitely a pin pallet (or pin lever) movement, this one with 25 jewels, so quite an interesting movement to work on if you've not come across one before.
Anyway, this one has you name on it if you want to pm me an address.
  • 5 years later...
hi all. just purchased a broken supernova that i am trying to fix. The movement is the one jewel variation. seems pretty gunked up, having a hard time getting the stem out. any suggestions from experience of working on this movement? Let me know, thanks!!
    • Personally I would salvage the missing screws from some donor movement.  I also bought a random selection of screws "Assortment of Stainless Steel Watch Screws" for next to nothing.  As for using an Alum solution - I had great success with that removing a rusted stem from a stainless steel crown.  The best piece of advice I read on doing that was to keep the solution warm so that the reaction didn't take weeks!  I did it in a couple of hours with the solution in jam jar and the jam jar in a saucepan full of water which I left on an induction hob maintaining about 60C in the Alum solution.
    • I decided that it was time to tackle the piece that I'd set aside as my first project. The subject in question is a Gruen Veri-Thin pocket watch.  It winds and "runs".  On the time grapher, it has reasonable amplitude (240 or so depending on the position), but was loosing close to a minute a day.  The stem also has the annoying tendency to just come out when pulled, which makes it super hard to set the thing.  As with many things this one started sideways and just got more so.  I was able to overcome the mangled "tab" on the back case cover (a well placed, very sharp knife enabled me to get in when I couldn't get a purchase on the mangled tab with a case knife.)   I was then sort of shocked to find that one side of the dial was held down with some sort off tape or adhesive material as someone had broken the dial foot screw on that side and left the broken screw in the mail plate. The loose stem does in fact seem to have been a poorly tightened setting lever screw, but I'm afraid there may still be gremlins in the keyless works.  While I was able to get the stem to stay in by putting everything in the right place and tightening the setting lever screw (before I took it all apart for cleaning and inspection), it just didn't seem to all sit right. The final gremlin showed up when I was taking off the lower cap stones for the balance and escape wheel (yes the Gruen 380 seems to have a cape jewel on the escape wheel).  The balance stone came off fine (but that in fact is the smallest screw I've ever seen.  When I turned the movement around to get the one off the escape wheel setting, I found that the screw head had been mostly sheared off.  After some reading and looking at what I had, I decided to try and tease what was left of the screw out of the hole by nudging what was left with the corner of my smallest screwdriver.  After 20 minutes or so, I was able to get the remains of that screw out. The picture I'm including of the disassembled movement was taken before I got the second cap stone off, so in the picture, it's still attached to the main plate (for those looking carefully, you'll only see the one cap setting in the pic.) Now I'm left with: A broken dial screw inside the main plate that needs to come out A broken cap stone retention screw that I have in my parts tray, but that is strictly useless and needs to be replaced. The need to get another dial foot screw I'm contemplating solving the first problem by soaking the main plate in an alum solution.  I think the main plate is brass and shouldn't be affected, but I have not been able to confirm.  This seems like the easiest option as I can't really access both sides of the screw to use the pricey Bergeon tool (which I don't fancy buying unless I have to.) I have located a couple of donor movements and have questions out about whether or not the include the dial foot screw and prompting for pictures of the dial side so  evaluate the cap stone settings.  I've also found that a supplier in this country does have the cap stone settings, but isn't overly clear about whether the screws are included. Are these the types of things that one can scavenge out of assortments or is it best to just grab one of the donors assuming that they look like they have what I need?
    • I visited this place last year just before they closed their counter service - amazing shop (filled from floor to ceiling!) and the guy that was working there was really knowledgeable and helpful!. Their website isn't as good as Cousins but I understand that if you fill out the contact form they have stuff that isn't on the site. https://gleave.london/mineral-flat-bottom-domed/
    • As always in this game the answer is “it depends “ because the first one worked out ok doesn’t mean all will. A case could be made in a way that it would not really matter much, sounds like your first example. However a case could also be made so that only a tension armoured crystal could be used. Generally you replace like for like to maintain the integrity of the watch.   Tom
