I just finished painting this and thought you guys would get a kick out of it.  Its a Hauser M1 watchmaker's jig borer.
I normally worry about getting my machines in good mechanical shape and don't care about paint (if you're using them, the paint will look like crap after a year of chips and coolant in any event) but this little one was worth it.  Its primary used by watchmakers as a jig borer and mill.    Its direct reading off the dials in ten thousands of an inch with lead error correction (the marker for the dial moves and follows a profile to correct for any screw error).  Now it is a jig borer, but I'll say it is the nicest machine I've put my hands on, and that includes many of the worlds best names including other swiss stuff.  Exceptionally well made.
i bought yet another mill and lathe before Christmas and ended bringing this one home as well, they don't come up often and it just too cute.  Wear is negligible with the original scraping well defined everywhere.  The only flaw was the paint was literally falling in big chips - another good reason to paint it.  I chipped all the old paint off, it was so thick, feathering it was a real challenge, so just took it all off.
I have the spindle (8mm collet) and drill gimbal but I'm going to have to make the microscope.  Used for locating, the microscope is an important accessory as they are also used as an very toolmakers microscope.
I have the original stand, but no room for it at the moment.  They powered these things from a motor hanging from post, much like a foredom.  The ideas was to isolate the machine from vibration....not sure yet how I'll go about it but I've some ideas
Edited by measuretwice
9Vphc58.jpg&key=76b9a0c88cb9d0b095f0d0f5987ba258222ff216884641ec46f0d5c0477a302e
uvxKHfs.jpg&key=16860d947c2a8f295da54e050771eef64ccfa9fd1cba156c332f232f9d5f10dd
gLz7BWm.jpg&key=058c85bb9aa5283cac1c6f1de36b5010628e066e48dfcaf1422faf32bc975066
That’s nice I bet it’s heavy well done
Thanks....yes it is heavy.  Disassembly required!  There a bit of pain to move as you have lift from the bottom or you bend the screws, which are  the heart of it.  each layer just sits on top of the other only attached  by the screws
looking cool is its main function  :).  A jig borer is primarily used to make holes - very, very accurately placed holes.  It can also be used for light milling, which anything in watchmaking pretty much is.   This particular  machine is highly favoured by watchmakers because of its small size and accuracy.
Of all the machines I've got, it'll probably be the least used, but I like the tools and its been on the wish for a long time.  The law of diminishing returns has definitely pushed this toolaholic way out on the skinny side of derived utility, but I'm still having fun :)
Well, if its main function is looking cool, its fulfilling its main function with flying colors :biggrin:
Bet you could make a dial on that thing - if you have a ton of patience.
Nice machine!
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
