I would like to hear some advice how to check the movement condition without removing any parts from it? I do have a timegrapher, but it won't always tell you is there oil at all in the movement. It would be much nicer to sell a used watch if you know that there is good oils in the movement. Which kind of loupes/microscope are needed (how much magnification)? Any essential tips are welcome, how and where to check etc.
A watch movement is a pretty complexe and complicated thing and you CANNOT do that the way you want it.
You can check some parts which are out in the open but not all of them.
A proper inspection and servicing requires a strip down to the "bone".
Yep, I knew this =) My mission is to learn hiw to check these parts which are possible to check without disassembling the movement, just to confirm that the movement isn't totally dry.
Sent from my ONEPLUS A5000 using Tapatalk
I don't think you're likely to come across a watch movement that hasn't been lubricated, and the oil once applied theoretically doesn't evaporate. What does usually happen is the oil thickens or otherwise loses its properties. It's a safe assumption that some sort of oil in some sort of condition is present.
As far as I'm aware there's no trick to knowing the condition of the lubrication other than general inspection, testing how well the winder functions and looking for low amplitude on your timegrapher (which i like to stress is only an indication and might mean something else or might mean nothing at all)
Edited by Ishima
how to learn to service a watch mvt.:  4 years aprentiship as an instrument mechanic or jeweler OR - trial and error work on cheap watches.  vin
    • I'm struggling to find information on adjusting a Seiko bracelet. I can pull the locking pins out but the links remain very much together. I don't want to bend anything without being sure I've tried everything. Anyone else adjusted one of these?
    • Thought I’d say hi. I’m from outside of Glasgow and have a small collection of watches, which I love. My love of all things watch comes from my Gran having been a Jeweller, and also from being the custodian of a 1979 Omega and also a few vintage Timex mechanical watches. I have some more modern watches as well and i love them all. I’ve recently started looking into watch repair and assembly as I’d love to know more to see if I could work on / service some of the watches myself. To that end I recently assembled an inexpensive automatic GMT using odd parts, a Seiko movement, and by referring to many YouTube videos. Hand setting caused me no end of pain and once I receive a new second hand I’ll try again. Difficult but very therapeutic - many thanks in advance as I’m sure to ask so many “stupid” questions. Best Regards
    • Few years ago I needed to fix a Cornavin my granny gave me (believe the mainspring broke). I couldn't find a watchmaker. There's a keycutting chain in the UK called Timpsons who said they could post it off somewhere and it'd be £250. I wondered around town for a bit and realised that watches are made by people (duh), I'm people, so I can probably give it a go. I did a bit of research, bought a little tool kit, and proceeded to break bits (shock absorbers, naturally). I then put all the parts in a bag for safe keeping.  Since then I've developed a healthy fascination with the subject (not an obsession, just a healthy - think about it everyday now - kind of fascination), and amassed a good bit of literature and some cheapy tools. I still haven't fixed the Cornavin (it's a 2614.2H movement, same as a Poljot and I have enough spare parts now) but it'll be the one after my next project. Currently assembling a Raketa 2603 for the practise. I took out the little shock absorbers, struggled to put them back in, walked away for a cuppa and searched the internet for any tips. Then I found this forum, been here before actually, figured I'd join. I feel like I've developed a smidge more book knowledge than practical skill, so that's a point I need to work on. I'm having doubts the Raketa will work once I'm done, but it was cheap enough not to matter and worth the practise. So here we are. Hello
    • I was thinking it might be nice to see a picture up above or the picture I'm going to paste down below from up above with the escape wheel just setting their. Then it almost looks like the lower jewel is out quite a ways? But maybe it's an optical illusion with the shellac yes the assortment set over time have become something other than what they once were. Like it work with a assortment of Waltham jewels for burnishing in and the last time I tried to find one I discovered there all randomly assorted. Then of course often times the assortments had a tiny quantity of things and the entire container got re-tasked for other things and down the road somebody sells it totally clueless of what they're selling. But in the case of roller jewel's especially after the longer ones of pocket watch size for a single roller then randomly and bottles is definitely good. If you really careful you may be able to place the roller jewel on a flat surface and use calipers although a bench micrometer really is preferred.
    • Have you search for a new winding crown using Tissot case id? You can also find a replacement crown by size / type of the crown you currently have: https://www.cousinsuk.com/category/tissot-crowns-by-size They are dirt cheap.
