I have worked on a few ladies' baguette movements lately for some friends and relatives. On these, even the simplest jobs are challenging. At least they are for me. This made me wonder whether watch repair people charge more for working on these little 5 1/2 ligne'ish gems? While I'm sure it gets easier with practice, it seems that mishaps are more likely with these small watches. I mangled my first hairspring on one. :pulling-hair-out: I wouldn't be surprised if watchmakers turn the work away for this reason, or at least charge 25-50% more for working on baguettes.
Oh, this brings my other question to mind, is "baguette" the proper term for watches in the 5 1/2 x 7 ligne range? Cheers.
Yes, they are quite unforgiving and difficult to hold, etc. I'm working on my GF's heirloom 4LLV/13.15 Longines baguette right now. That's the one I killed the HS on. I got a parts movement and cleaned it very carefully. Every screw is a special challenge. Despite this model using a well-advised balance-guard at the perimeter, it's still dangerous to hold from every angle.
I have it running nicely. Unfortunately, I put it back in the 14k case, and the winding arbor doesn't seem to be going deep enough to stay in wind position. It's like the crown just won't get close enough without hitting the case. The watch stops while it's in limbo. There's a little bushing that goes between the case and the crown. It almost seems like I'll have to shorten that bushing. Truth be told, I may have mixed up the bushings between the original and parts movement. I plan on taking a depth measurement on the two bushing tomorrow to see if there's any difference. They look the same to the naked eye. Well, at least I've got it running. That's a step in the right direction. Cheers.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
