Hi Everyone,
I have a nice little Uno vintage watch that has a broken strap pin.  The case is only base metal and the pins appear to be cast into the lugs.  What would be your advice for repair or repair?  Many thanks for your help.
Peter
An easy repair, so to speak. You just solder/weld a new lug pin. I guess you have to remove the remaining bit and then polish or file the area to flatten it and then you just solder a new one.
Hi Chopin,
thanks for the speedy reply!  I'm assuming I could just use a little piece of bar stock of the correct diameter from my materials supply company?  Thanks again for your help,
Peter
As Ishima points out you'll have to do a bit of research to see what type of metal to use and what type of technique to use as there are a few out there. Maybe laser welding might be a good and clean job with no excess metal gather around...
Yes, absolutely.  I have no jewelery soldering experience - only electrical.  It would be a skill worth developing.  Youtube is a great resource!
My advice is to get the lugs drilled, so to be able to fit springbars, and any strap you want.
Plus drilled lugs are one of these subtle watch buff show offs.
29 minutes ago, jdm said:
My advice is to get the lugs drilled, so to be able to fit springbars, and any strap one wants.
That's a good suggestion too.  Thanks!
If the base metal is brass then it’s pretty easy. I use soldering paste and stainless rod. Use calipers to measure original rod thickness.
Hard soldering is a skill, and you should definitely practice soldering a spare piece of your rod to another similar scrap base metal like your case.
As it looks like a cheap watch though, you may be best going with JDM’s suggestion and just pierce the lugs to allow spring bars to seat. The holes will deteriorate if they are unplated brass though. Seen it happen enough times.
Yes - drilling the lugs is looking more attractive.  It also plays more to my skill set.  It is a cheap watch and the case feels like a die-cast metal so it shouldn't be too difficult to drill.  Famous last words....  I'll post pictures either way!
Thanks to all respondents for your advice.
Mount the case securely, and punch where you intend to drill, before using the smallest pilot drill you can get to create a pilot.
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement
    • Once you are aware of the problem, you can adjust as necessary. I have a couple of the Omega 10xx, and they are not my favourites. They seem a bit flimsy and not as solid as previous generation Omega. But I think that's true of a lot of movements from the 70-80s. For me, the 50-60s is the peak in watch movements, where the design criteria was quality, not saving the last penny.
